Topping E30 II DAC Review
Rate this DAC:
    Votes: 14 4.3%
    Votes: 22 6.8%
  • 3. Fine (happy panther
    Votes: 103 31.7%
    Votes: 186 57.2%
Anderlfs
Brasil
ok, but how could the outputs on d10 be bad as to cause a ~20db difference? lots of cheap ass dvdplayers around with questionable design. then there`s the bits are bits argument.
That's why It would be nice. He could however have also tested directly from a TV to discard any problem with his D10, or with something in the way, isn't that how @amirm tests? Isn't that how most will use Toslink?
CauliflowerEars
That's the most important thing..! ;)
Well, I've just upgraded to the Topping E50 and I am even happier (probably +20-30%) ;)
Now I am afraid to listen to the more expensive DACs. It seems the next step up would have to be in the 600-800 USD range, if I am correct (Topping d70s?) ...
It's crazy how better the E50 sounded to the E30 II. Fuller, some sounds had more details, strings rung more/longer, making music more enjoyable.
I even heard more detail and modulation in the cosmic sound from 4:40 in Daft Punk - Giorgio by Moroder.
Gosh, now I am really curious (and afraid) how the best DACs sound ... :)
Veri
So uh, E30 ii is RCA output, are you using E50 with XLR output? Resulting in increased voltage and volume levels? Because it's extremely doubtful DACs of this caliber can sound so different unless you changed the whole set-up by a lot..
Hapo
...I am glad some one knew how to say this...
...Amir might say you are listening more carefully...
CauliflowerEars
Nope, everything was the same. Exactly the same cables as well. Although, the E50's RCA was even 80cm longer and the USB 1m longer.
(tbh, I don't yet know when/if it's worth using the XLR output ... is it?). UNLESS, my MBP 15-inch, mid 2012 has two different USB outputs OR my old Pioneer A505R amp's Tuner and CD inputs are different ... Have you compared the E30 II to any other DAC?
Yello - The Race (Remastered) - known for its stereo effects: https://tidal.com/browse/track/64627076
E50 - deeper and fuller. I got dragged into the song. It became a ... 'trip', so to speak.
E30 II - flatter. The sounds were more like information, less engaging and definitely didn't drag me in.
Eva Cassidy - Ain't No Sunshine - apparently often heard on audio expos: https://tidal.com/browse/track/53262839
E50 - the singer was less ... restrained. The echoes and instruments sounded longer, especially the strings. The bass and strings were fuller, I felt more vibrations. The music sort of engaged emotionally more.
Daft Punk - Giorgio by Moroder: https://tidal.com/browse/track/20115559
In the beginning, I thought it would be difficult to hear the differences in such a well produced and complex song. But:
E50 - the cosmic sound from min. 4:40 was more complex, I heard its modulation, which was more engaging.
E30 II - it was more flat. Just a sound with nothing special ...
Do you mean you like my description of the differences or Veri's calling out my BS? :)
I had to listen carefully (is that sth strange?). It was an AB purchase test after all. I have to say the differences were in the range of 20-30%.
In the beginning I wasn't sure, if to upgrade*, but the Yello 'trip', Cassidy's emotional engagement and Daft Punk's cosmic sound complexity helped me make up my mind.
We (at least I) are doing this for the musical engagement and experiences, after all ... For me it was definitely worth the extra 65 eur.
Now my big questions are:
1) How much better are the other (more expensive?) DACs? From one review it seems a Topping d70s would be the next upgrade (about 566 eur, so 2.7x more than E50).
2) Are there other DACs that would be a good upgrade for not so much? The E30 II -> E50 jump was cheap enough to be a no brainer. I like those :)
* also, the smaller E30 II fits nicely on top of my amp, not standing on any of the venting holes and the bigger E50 is above 2 row of those ... I hope it's not an issue ...
Rottmannash
Nashville
Don't have the E30 II but have the OG E30, a D70, a D10 Balanced and a D90SE and don't believe I could discern a difference between them in a blind test-they all sound the same.
gegegege
There are reviews indicating the missing details from E30, such as this one https://soundnews.net/sources/dacs/topping-e30-dac-review-entry-level-overachiever/
"The only thing that I could complain about compared to a high-end DAC was the detail retrieval that was not its best trait, I would spot some micro-details but only with my eyes closed. They are still there, but are not screaming for attention and prime time. Treble lovers would be slightly disappointed to know that E30 is playing the safe game, rendering it natural and clear but without the over sharpening some DACs are doing nowadays."
CauliflowerEars
Well, from what I know, seems the OG E30 is worse than the mk2. I’d assume you’d hear at least some difference … why would the D90SE be so expensive, then?
I suppose the rest of your system is also of good quality and you are listening through USB from a high quality source?
Would be interesting, if you could listen to the three songs I did.
CauliflowerEars
Seems similar to my experience. Although, maybe less about the treble. And, I did test the E30 mk-2. New beautiful black packaging, sealed. And it had the ‘II’ on it.
gegegege
Also noticed E30II uses AK chip while DX7s uses ES chip, could be the cause of difference?
Veri
Big White
Is there a difference in sound quality when you connect the E50 and E30II via toslink with wiim mini?
Sokel
There's quite a "differences" party going on here and in the E70 and E70V threads.I thought that people would jump to them but...
Interesting thought.
Joel G
Respect for this! I am in it for the same reason, and that keeps me coming back here to check info and experiences on devices that I am considering buying.
However I no longer feel for discussing any (subjective) impression I might have on devices here, after I was put on my place for trying to discuss such matters in ASR. And it’s alright, no hard feelings, it is after all audio Science review, and the premise for what I was made to understand is that all DACs sound the same etc etc and if I happened to differ from that opinion I should rather keep it to myself. Which is what I do now. Once in a while though I am happy to read posts like yours knowing
I might be wrong but not alone
Sokel
The suggestions about the subjective impressions is not to keep them to yourself but to prove them to yourself (it's your wallet after all) by listening to them properly under proper conditions.
The benefit will be yours if you eliminate one by one any variable truthfuly (to yourself always,we internet people don't sit in your sofa)) and focus to the ones that truly matters (room acoustics,speakers,nice headphones,etc).
Honken
Scania
No, not all DACs sound the same, but all competent DACs sound effectively the same. There's quite a few broken DACs out there, and this is not one of them. In fact, it is more often than not the expensive boutique designs that are the broken ones.
I have one of these and I am quite happy with it, looks smart and it was cheap. I have a L30 II / E30 II combo that replaced a JDS Element 2 that got banged up when I accidentally dropped it. Don't really hear a difference in sound quality between the two setups, but the noise floor is noticably much lower with the Toppings. Can't really figure out why, but I only hear the difference with IEMs.
DSJR
Suffolk Coastal, UK
I can't at all challenge your subjective views here BUT - Maybe a silly question but I ask anyway -
Are these the links you used when subjectively evaluating? Tidal is MQA hobbled now pretty much isn't it? if so, the E30 will be giving a thirteen bit reproduction (with much reduced S/N playing back the MQA files) and the E50 as well as having higher output potentially? will 'unfold' the MQA files with all that this entails..
