New to the PA5 II Plus team.
It came on Monday and sounds nicely.
The sound is balanced, neutral, without coloring. The better the source is, the better the output will be.
Playing FLACs 16/44.1 to 24/96-192 from Sony UBP-X800M2 through my SMSL D-6S.
No sibilance, no boominess. Stereo image is nice.
My old cheap bookself speakers (Crystal audio TX-B1) are neutral sounding, 89db/W sensitive, 6.5'' glass fibre woofer + 1'' silk dome and I'd say that they couple nicely with PA5 II plus.
I' m a bit confused, about what cables to buy in order to connect balanced the D-6s to PA5 II plus.
XLR to mono 6.3 TRS microphone cables?
Unbalanced signal cable with a 6.3 millimetre TRS plug and a female XLR plug. Uses original Adam Hall plugs and high-quality cable material.
www.adamhall.com
or
XLR to stereo 6.3 TRS microphone cables?
Balanced signal cable with a 6.3 millimetre TRS plug and a female XLR plug, thus suitable for transmission of sensitive microphone signals to the mixing desk or amplifier. Uses original Adam Hall plugs and high-quality cable material.
www.adamhall.com
