The new Review Index looks great and is a significant improvement. Thanks to all who worked on it! Having said that, here are some areas for improvement.
The gray "row highlight color" that appears when you hover over a row in the index is too close to the darker color of the alternating colors of the rows. Something like a light blue color (maybe the same color as the outline around the "Search" text field) would be a better choice, IMO.
The "Review Link" for the Revel F226Be points to the Revel site not to the review.
In the Advanced Search, the "Speaker Type" should be a select menu instead of letting you enter free-form text, since there is only a small number of speaker types and people might enter text (e.g. "floorstanding") that doesn't appear in the index.
The N/A entries for "Recommended" are inconsistent and confusing. Some of the entries actually are recommended. In Amir's review of the JBL 305P Mark ii, he writes (in bold), "I can definitely recommend the 305P Mark ii." Other entries are recommended, but by reviewers other than Amir. For example, napilopez speaks very highly of the Dutch & Dutch 8C. Perhaps it should be noted that the "Recommended" column really means "Measured by Amir and recommended by him". Or maybe the entry in the recommended column should mention the reviewer (e.g. "Yes, by napilopez", "Yes, by Amir", etc.)
