I'm really sorry but I don't have an equipment nor necessary knowledge to be able to repeat your tests...me
I'm just waiting for someone to prove me wrong... no worries...
or that my wiim has broken down...?
Honestly, I don't take pride in it.
do it..
firm 432755
home 221018
but I think the case since previous firmwares..
How do you capture the output of Flex? Is another PC/sound interface or is the same running the test signal?I've repeated my test with analog output to be sure it's not toslink out-in or optical cable related. Unfortunately still the same issue.
Flex is able to send its output to the PC over USB interface for any input used as it is both AD and DA converter. I capture it with ocenaudio using ASIO drivers.How do you capture the output of Flex? Is another PC/sound interface or is the same running the test signal?
It seems that in the USB case, some sync between sample points time is kept, whilst in toslink case, samples are not time synchronized and sample point can or cannot take the peak of impulse.
You can run Qobuz from the WiiM Mini streaming application, with a look and feel pretty similar to the Qobuz app itself.Qobuz, which is otherwise reduced to a 1990s throwback experience through bubble upnp or mconnect.
Does it give access to the wider features of the app? My experience of other software using their api is that half of the playlists views so are missing, as are all of ghe articles etc.You can run Qobuz from the WiiM Mini streaming application, with a look and feel pretty similar to the Qobuz app itself.
I think so, though I'm not using 100% of the features of the app.Does it give access to the wider features of the app? My experience of other software using their api is that half of the playlists views so are missing, as are all of ghe articles etc.
So, the same usb and therefore the same PC, are involved in the in and out passes of that test. This could be explain the synchronized sample points (just a little process delay).Flex is able to send its output to the PC over USB interface for any input used as it is both AD and DA converter. I capture it with ocenaudio using ASIO drivers.
Waveforms look very similar in case of WiiM for both toslink and analog outputs.
You are measuring analogue output distortions correct ?for you at 44k16bit ;-)
the actual distortion is in mode no eq at 44k to...
as soon as we approach 0dbfs
fast measurement
to this date
same protocol at -0.1dbfs 998hz 44k 16bits
recently (for example mid-September), the differences were minimal on such a basic measurement in toslink, with chromecast wiim, normal.... (just the wiim which has significantly more jitter than the chromecast)
but now
There is the ASRC always involved on Flex side, so I guess it doesn't really matter that I send and receive signals on the same interface. Moreover WiiM's analog output is affected the same way so it cannot be something related to the spdif clock.So, the same usb and therefore the same PC, are involved in the in and out passes of that test. This could be explain the synchronized sample points (just a little process delay).
Maybe I'm wrong but a different device should be used to capture the output, possibly at higher sample rate than signal subject of test. The imbebbed wiim toslink clock cannot be in sync with the USB and is possible that sometimes it is sampled the very peak of signal an sometimes not.
Is just my opinion...
Sorry, I was meaning wiim internal clock, regardless the kind of output.it cannot be something related to the spdif clock.
Maybe you're right and I'm completely wrong as I do not have any expert skills in the measurements area. Differences I can see still intrigues me so do those observations related to possible distortions. I'm going to repeat my tests after FW downgrade if possible.Sorry, I was meaning wiim internal clock, regardless the kind of output.
I don't want to defend wiim but it's unknown how flex manages that return bus,under different cases.
Despite everything, it would be interesting to see what would happen to the signal produced by the PC and any other sources, when captured on flex analogue output by an external device.
I'm not absolutely meaning that, it was generally speaking, any experimental results have to be confirmed by a different kind of test.Maybe you're right and I'm completely wrong as I do not have any expert skills in the measurements area. Differences I can see still intrigues me so do those observations related to possible distortions. I'm going to repeat my tests after FW downgrade if possible.
Agree with thisSorry, I was meaning wiim internal clock, regardless the kind of output.
No, they don't look good, even for usb should be better.Some THD measurements made in REW for 96 kHz sweep signals, vertical scale in dBFS:
Does it look good? I don't think so.
Agree - this is proof your measurement method is sub-optimal @onlyonemeeven for usb should be better.
