Those harmonics of 70hz I think are more likely due to the transducers (cone and mike)Your first screenshot seems to indicate that your WiiM can be affected as there is a peak of 3rd harmonics possible at 210 Hz.
Maybe, but the one I've mentioned is not visible on the second screen. 3rd harmonic was always the most obvious in my measurements when distortions happen.Those harmonics of 70hz I think are more likely due to the transducers (cone and mike)
Yes, I was meaning that 70hz had anyway a certain distortion, in a frequency range less hearable than around 800, where the harmonics are at least -40 dB, not so easy to catch in a room.Maybe, but the one I've mentioned is not visible on the second screen. 3rd harmonic was always the most obvious in my measurements when distortions happen.
It should help as well on toslink if you lower the volume of WiiM. I've seen such improvement.I had not done the tests
but or on the analog output, lowering the variable output level a little makes the problem disappear.
and is not linked to the "2v 1v 800mv 500mv" ...works well in the digital field.. upstream..
thank you merifon for having observed it because at least I will be able to use my wiim in this way!
analog output by barely lowering the level!
already that...
Yes, it's the only workaround working so far. Of course you loose "bit perfectness" for all signal levels.yes
i spent a lot of time on this
without checking this point "via variable output"...
stupid that I am..
the problem remains unclear..
but manageable in the meantime..
That's why I suspect thisthere must have been a bug in some cases shifting the 0dbfs when trying to tinker with saturation issues in eq modes...which also affects no eq mode
i dont now with...Four users reported distortions issue and two users reported no such issue so far if I counted correctly.
I also pointed it out a while ago... ;-)That's why I suspect this
"Fixed - EQ clipping when using the fixed volume option or playing music in high volume"
Testing on 430138 will give an answer.
Distortion range goes down to -1.1 dBFS for sine and it happens as well on WiiM's analog output. Sound level is also attenuated by -1 dBFS for sine in the clipping area. I cannot see such behavior on any other of my equipment. I doubt it can be external DAC related.It could even be a problem with some dac.
In the DO100 archimago tests is reported: "Note that all of the filters showed intersample overload with the 0dBFS Wideband White Noise signal. This basically means that the filters do not provide a full +3dB overhead to cover most of the overload situations we might run into".
Who says? I should buy an RME ADI-2...
