Yamaha A-U671 Integrated Amp & DAC Review
Doodski
Are you asking abou the tone control characteristics?
I would opine (and that's all that this is, an opinion based on anecdotal information & memory!) that they're not uncommon, although the range is (or may be) somewhat more subtle than tone controls of the old days (to wit, the 'seventies). The turnover frequency is on the high side, though, similar to the old days' typical tone controls.
Since I just happened to look this up yesterday for a tone control question Someplace Else :) Here's a pretty typical, slightly high-ish-end tone control scheme for Yamaha's ca. 1978 CR-2020 receiver. This one has two different turnover options: 500 Hz (pretty typical) and 125 Hz (more subtle and 'audiophile', with respect to this component's era). This graph (from the owner manual, and I apologize for the quality of the reproduction) shows the maximum range of the controls -- which is pretty unsubtle.
Note that this receiver also has a boost/cut "Presence" (midrange) tone control as well (and for better or for worse). :oops:
CR-2020 is on the right in this glamour shot of two almost-super-receivers from the mid/late 1970s :)
Semi-monstrous 1970s soiled state receivers by Mark Hardy, on Flickr
(as befits the stature and maturity of these two grandes dames, this photograph was taken with 35 mm film ;) ).
Yamaha made up for their fairly ordinary tone controls, to some extent, by offering a variable loudness control in most of their components for quite a few years. The variable loudness was (is), arguably, more useful in the real world. But, again, that's just an opinion, too! :)
I remember using that Yamaha 2020 receiver well. It was a party machine battleship ;)
mhardy6647
I've only had one for 10 or 12 years; I did buy that one restored so it wasn't... ahhhh... cheap. :oops:
I thought I had the vertical tasting of that era of Yamaha receivers, until I realized that there actually was a CR-3020 :p
The CR-3020 came - as best I can tell - a little later than its CR-**20 brethren (sistern?), and a little before the CR-**40 family of receivers.
I was (inexplicably) unaware of its existence when it was new.
They're not terribly common (although it's not particularly to find one for sale nowadays in the usual venues)... but they also ain't cheap. I.e., I am not likely to ever add one to the collection (not that I really even have any place that could actually accommodate its size or its weight). :rolleyes:
(borrowed image, needless to say!)
anmpr1
.. Compared to the pots in the 70s that had the detent built into the pot-body itself, it's a roundabout way to get the "feel" they wanted.
I recall owning a then 'high end' tube preamp from an outfit called Counterpoint. Had that era Mark Levinson preamp look--with tubes! The volume control made little clicks as you turned it, making you think it was somehow 'calibrated' in accurate fractions of a dB. I found out that it was just a metal ratchet washer giving it 'the feel' of something special. It was easy to pop off, allowing for a smooth turn of the wheel. LOL
Toku
Japan
YAMAHA has several product development groups. Audio group, AV system group, home appliance group, etc. WXA-50 is a product of the AV Group.
I think that this A-U671 is probably a product of the Home Appliances Group. When I first saw this product, is this a YAMAHA product? I was surprised with.
The old YAMAHA products you have shown in the photos are products from the days when the YAMAHA audio group was most brilliant.
My favorite YMAHA products are CA1000, CA2000, NS1000M. I used a $ 600 / pcs YAMAHA JA-2070 alnico magnet 20cm full range unit for my old homemade speaker. That was when I was most crazy about audio.
mugbot
Adelaide
So I'm a new member, and I happen to own one of these so I thought I'd look it up on this forum and yeeeesh. That is not exactly a glowing review!
My question is whether upgrading this amp to something better (I'm considering the Peachtree Nova 150) would audibly improve the sound? It's driving a pair of DALI Zensor 3's. I also have a minidsp DDRC-24 on the way to experiment with Dirac if that is of relevance.
Brit on a Budget
Hello.
I have the Yamaha A-670 (UK) [the non DAC version of the A-U670/A-U671] and did a teardown of that for comparison, if anyone is interested.
The 4 photos show; top down view, inside front of daughter boards, close up of chip package, and a bonus image showing metal weights.
Yamaha could have easily packed this whole amp into the space of the Topping PA5, so to give it the illusion of being packed with heavy components, they screwed in 2 heavy steel plates to each side (see figure 4) to give the false impression of heft. Note, the metal plate is rusting.
Regardless, the design is lovely and simple but if it wasn't for the poor noise performance it could be a stellar amp.
Regards.
