AIYIMA A300 Review (Stereo Amplifier)
Rate this amplifier:
    Votes: 33 17.0%
    Votes: 120 61.9%
    Votes: 38 19.6%
    Votes: 3 1.5%
This is a review and detailed measurements of the AIYIMA A300 stereo amplifier with balanced and Bluetooth inputs. It was sent to me by the company and costs US $177.
I like that you can easily defeat the tone controls now and select one of three inputs, allowing the amp to replace a pre-amplifier as well.
Especially nice is inclusion of power supply which is a rarity in budget/small amps:
AIYIMA A300 Review Back Panel  Stereo Balanced Bluetooth Amplifier TPA3255.jpg
The speaker terminals are small but typical for the price class.
I could see an aluminum heatsink in the box for the power device/IC. In use though, it never warmed up above room temp. Neither the top, or the bottom registered a temperature rise which is nice.
AIYIMA A300 Measurements
Let's start with unbalanced RCA input first, setting the gain to 29 dB as with other amps I test with adjustable gain:
Switching to balanced we essentially get the same performance:
That distortion spike at nearly -72 dB limits SINAD to below average:
In fairness and comparison to a few amplifiers with much lower gain, I also tested the amp at 12 dB gain:
A bit better but still not enough to cross the average line. For the rest of the tests, I stuck with XLR input and 29 dB gain.
Here is our SNR:
These are disappointing numbers relative to what AIYIMA has shown it can do.
Multitone test result is not too bad:
Crosstalk is good:
Frequency response unfortunately shows load dependency:
AIYIMA A300 Measurements Frequency Response  Stereo Balanced Amplifier TPA3255.png
Key here is to see if we can get more power out of this small package and we do:
AIYIMA A300 Measurements Power into 4 ohm Stereo Balanced Amplifier TPA3255.png
Interestingly, we get almost as much with 8 ohm load!
AIYIMA A300 Measurements Power into 8 ohm Stereo Balanced Amplifier TPA3255.png
Back to 4 ohm load, with short bursts we get a lot more power:
AIYIMA A300 Measurements Peak and Max Power into 4 ohm Stereo Balanced Amplifier TPA3255.png
Finally, there is little frequency/power dependency which is very good for a class D amplifier:
AIYIMA A300 Measurements Power into 4 ohm vs frequency vs distortion Stereo Balanced Amplifier...png
Warm Up Time Measurement
Amplifier stabilizes quickly:
It would have been great if the A300 had followed the footsteps of previous AIYIMA amps but with more power. Alas, it delivers on more power at the expense of noise and distortion. Assuming you don't hear the noise, it may be the right trade off in a budget amplifier. On packaging, I really like the integrated box with XLR inputs. Amplifier power supplies can be huge and that is avoided here.
I am personally snobbish and want my power with low noise and distortion so can't recommend the AIYIMA A300. But your priorities may be different.
PeteL
You used to do ultrasonic performance for class D amps, as it been forgotten or just not of matter in this case?
respice finem
Here is our SNR:
Crosstalk is good:
Way too expensive for how it performs and its features.
If I needed an amp like this, I would forsake the XLR and get the Loxjie https://www.audiosciencereview.com/forum/index.php?threads/loxjie-a30-amplifier-review.17547/
VintageFlanker
Paris
Thanks for the review.
Kind of meh results. Literally no headroom between 8 and 4Ω... I guess this will work terrible under lower impedances.
And get some integrated DAC this way... There is effectively no point for XLR inputs at this price and performance.
whazzup
Can the treble and bass controls be plotted as well? Will be good to know how extensive the influence is.
Tangband
Sweden
Here is our SNR:
Crosstalk is good:
This seems to be an amplifier with tpa 3255 chip inside. This chip can be driven in true balanced mode. The performance probably suffers because of the inbuilt powersupply in a very small box.
If one ignores the switched powersupply spike at 2 kHz (?) it would be a SINAD of 98 or maybe better ? What do you think about this ?
I used to run the FFT to see the switching frequency. Not sure how useful it is so I don't always run it.
If one ignores the powersupply spike it would be a SINAD of 95 or maybe better ? What do you think about this ?
There is a second harmonic in the 70s so you can't get better than that.
They are analog controls without much precision. I have tested them in other variations.
Tangband
Sweden
No. The Noise floor is also too high. Not to mention 2nd harmonic.
How do you dissociate an amp performance from its PSU anyway?
It might not be a very good idea with inbuilt powersupply in a very small box ? The Aiyima a07 measures better regarding sinad, uses the same tpa3255 and it dont have an inbuilt power supply.
whazzup
Thanks.
I did a quick search but couldn't find the review in which you tested the tone controls. If you remember which amplifier it was will be great. If not it's fine.
*If anyone else can recall the amplifier that had their tone controls tested, do let me know, thanks!
respice finem
That has half the power though.
Which really matters in typical applications of such a mini-amp? I doubt it, honestly.
At the desktop, or in a TV or a small room stereo setup, probably 10 watts per channel will be more than "loud enough" - and if not, there's a subwoofer output.
JSmith
Algol Perseus
Why do some people jump into almost every review thread and harass Amir about whether this was tested or that was tested? Just be happy that someone has taken the time to test anything for you, for free and show some gratitude.
JSmith
whazzup
JSmith
If you are talking about my asking about the tone controls a few posts up, I'm sorry you feel so triggered.
But equating my question with me not having gratitude for the reviews is way off base.
Amir didn't test them, so I asked. He replied, and that's about it. No one is taking things for granted here, nor am I demanding anything from him.
PeteL
Me I find this a nice set of features and decent power at a very cheap price. Probably sound OK for most. What surprises me tough is that the company would send that in for testing. They should really know by now the high standards expected here and that they would have got a poor review? Unless they are so small that they can’t afford measurment equipment but it would surprise me even more, they must be selling tons of these things.
JSmith
Algol Perseus
Sorry mate, not specifically you... it seems to be a trend in almost every review thread and it does become rather irksome as the claims are then often used to attempt to negate part of the results. Maybe I have chosen the wrong time and place to raise this, I was also reading some other review threads, it's been a long day. :)
JSmith
respice finem
...What surprises me tough is that the company would send that in for testing...
Maybe it's more for testing our response than the unit itself?
You can't have market research more cost effective than this way, even if it will be limited to our "bubble".
