Aragon 2004 MK II Review (Vintage Amplifier)
Rate this amplifier:
    Votes: 51 32.3%
    Votes: 76 48.1%
    Votes: 20 12.7%
    Votes: 11 7.0%
This is a review and detailed measurements of a "vintage" (1990) Aragon 2004 MKII stereo amplifier. It is on kind loan from a member.
I like the v-shaped design to set it apart from countless other boxes. Speaking of boxes, this thing is massive. It was designed to house the double power 4004 version with the same power supply. Inside is dusty and I am not sure if it has been refurbished or not.
If anyone knows what it sold for originally please, post.
Reading online, it is claimed that Dan D'Agostino of Krell and now D'Agostino amplifier company fame did a lot of the electronic design.
Note: please ignore the "4004" designation on the graphs. I originally thought it was that unit and didn't realize otherwise until the end of the measurements.
Aragon 2004 MK II Measurements
Warm up was uneventful and is often the case, performance got (negligibly) worse, not better, contrary to popular opinion:
Here is our usual dashboard of pushing a 1 kHz tone into the amplifier:
There is a ton of power supply related noise. So I shut off the input and saw some amount of it still there:
More on this later. For now, SINAD of 65 dB is well below the average of all amplifiers tested to date (around 79 dB). Dominant distortion spikes are 2nd and 4th.
Dynamic range is actually very good:
Crosstalk is not:
Swinging the other end again, frequency response is nice, flat and extended:
Multitone shows a lot of distortion spikes which is likely a combination of power supply noise and intermodulation:
Here is distortion+noise vs output power:
As you see from our two reference amplifiers (dashed lines), the usual slope is pointing down. This is because noise dominates the measurements when output power is low but once we increase the output signal, it progressively becomes smaller and smaller part of the original signal so overall performance improves. Not here. The line is flat. My best guess is that power supply noise is proportionally increasing with output power. So likely the filter capacitors are not doing their job. It could be an original problem or due to them aging.
Same is true of 8 ohm load:
Allowing for a bit more distortion, power specs are met:
Aragon 2004 MK II Measurement Max and Peak Power into 4 ohm Stereo Power Amplifier.png
Changing the frequency and making the same power measurements we get:
Aragon 2004 MK II Measurement Frequency vs distortion Power into 4 ohm Stereo Power Amplifier.png
Distortion lines for 1 kHz and lower are actually above their higher frequency counterparts. This is backward of most amplifiers and again points to power supply producing more noise as lower frequencies rely on them more.
At first I thought that an amplifier produced in 1990 would not be "vintage" but then realized that was 30 years ago! Time flies as they say... It is hard to know if this amplifier is running at original spec. I did not get any information from the member on that front. Looking inside, it is dusty and components appear to be original but I could not look closely. As is, performance is not special. There is a lot of distortion and classic tests like crosstalk show weakness. So I would not go out of my way to get one unless you have massive space you want to fill with a big box amplifier.
pma
Prague
Thank you for the review. This amplifier does not measure well.
Re your noise measurement, my question is, again - what is 0dBrA related too ??? 4.47V (5W/4R)? The graph as posted tells nothing. If it is 4.47V, the result would be quite usual for AB amplifiers of those days. If 0dBrA is 1V, then the result is good.
Yes. That is a quick grab of the dashboard which is always at 5 watts into 4 ohm load with the generator turned off.
anphex
Berlin, Germany
Is there a price to be found anywhere? I always give my ratings relative to the price tag sooo...
Jim Matthews
Taxachusetts
I owned the 4004 variant, driving B&W 801s.
It was two of these, in one chassis.
It was OMG heavy.
The 2004 was $1500, back in the Day, the 4004 around $2250 (but neither ever sold at straight retail).
Had mine for nearly ten years and sold it for what I paid (back in the 1990s).
milosz
Chicago
I wonder if replacing the aging electrolytic capacitors and doing a bias, AC balance and offset adjustment would clean this amp up quite a bit. Maybe checking if any resistors have changed values radically over the years would be worthwhile, too.
I often read that it is suggested to "recap" old audio gear, I would like to see from before and after measurements if recapping really does improve performance.
In the case of an old Heathkit tube integrated amp that I fixed up for a friend, many of the capacitors - some film caps as well as electrolytics- had changed value, gotten electrically leaky or developed high ESR. But that was a 65 year old piece of equipment that ran pretty hot from it's tubes all it's life- I wonder if recapping this 30 year old solid state amp would result in measurable improvement.
Pio
I owned the 8008 version which powered my old NHT 2.9's. I remember really enjoying that match back around '97 or so..
noel_fs
vintages are 70s-80s and there is supposed to be lots of good ones
this one seems like the average hifi audiofool $3k amplifier
pma
Prague
I really do not think so. It is an issue of wiring topology, PCB routing design and low amplifier PSRR. So very usual with power amplifiers of that era, class AB with linear PSU. And not easy to design properly with much better results. Time was/is precious in consumer electronic design. Who would pay someone to play around the thing for further 6 months. It was just good enough for the purpose.
Azathoth
I'd probaby put a bottle of wine on the v shaped notch right there. I know it's not a good place to put your wine but I just want to.
Gorgonzola
Southern Ontario
For people with an attachment to old piece of vintage equipment, I think the Aragon is an object lesson in why it's necessary to renew the equipment, especially, but not only, the power supply.
My Sonic Frontiers Line 1, 20+ y/o preamp, (partly an emotional attachment), I recently upgrade to "SE+". The upgrade included extensive renewal of the power supply. The upgrade was pricey; for that money I could have more than bought a Topping Pre90 or Schiit Freya Freya +.
gi.mpl
