PaperBoat
SONY Music Center for PC+ ASIO+ Equalizer+ Topping D10 Balanced?
Is there any Equalizer that support ASIO driver?
Kal Rubinson
Industry Insider
NYC
ASIO? What kind of equalizer are you looking for? Software or hardware?
Kal Rubinson
Industry Insider
NYC
Software...
Then there is no problem. Software EQ/DSP is an operation in the host PC and, commonly, as a component/plug-in to the music player application, e.g., Roon, Jriver, Audirvana, etc.. Consequently, any will be compatible with ASIO output if the host PC/app is ASIO compatible, as most are.
HarmonicTHD
SONY Music Center for PC+ AISO+ Equalizer+ Topping D10 Balanced?
Is there any Equalizer that support AISO driver?
Did you look here already?
For Windows eg APO EQ with the Peace skin.
But it is all happening on PC not as you described that there is a separate EQ.
Edit: see below the hint from staticV3.
HarmonicTHD
Equalizer Apo (with or without Peace) also doesn't work with ASIO. Only with Direct Sound or Wasapi Shared.
Ok. Then sorry. I thought it did, but I might not remember correctly since that was some 9months ago when I tried it.
PaperBoat
PaperBoat
But I want to play my lossy music files with Sony dsee hx and ASIO... The SONY Music Center for PC has an EQ that doesn't work with ASIO...
Kal Rubinson
Industry Insider
NYC
But I want to play my lossy music files with Sony dsee hx and AISO... The SONY Music Center for PC has an EQ that doesn't work with AISO...
Sorry. I am not clear about your signal path.
PaperBoat
PaperBoat
Music player > EQ > ASIO driver > USB > DAC > Speakers
*Please ignore my nerdyness as I'm a "newcomer" in the Audiophile world*
Kal Rubinson
Industry Insider
NYC
Please identify each of the devices.
dualazmak
The software XO/EQ "EKIO", which I use in my project, has very simple and straightforward GUI interfaces; and the two-channel trial version is free having all of the EQ functionalities. I assume very nice for you to start learning EQ with using EKIO.
http://www.lupisoft.com/ekio/
Please visit my posts here, also here; EKIO can work as "one-stop XO/EQ center" systemwide;
You would please read carefully my posts #297, #006 on my project thread for the details of full ASIO I/O with digital XO/EQ software EKIO.
You would also please find my latest system setup including EKIO, ASIO4ALL, ASIO, JRiver etc., here.
PaperBoat
PaperBoat
As I understand now the fact that ASIO isn't compatible with Equalizers and there is no way to use a EQ with ASIO driver and the SONY Music Center for PC, I'm now lean towards the Foobar2k or JRiver MC or something like that...
Foobar2k/ JRiver ⟩⟩ EQ? (Something like or better than the Mathaudio Headphone EQ?) ⟩⟩ Topping ASIO driver ⟩⟩ USB ⟩⟩ Topping D10 Balanced DAC ⟩⟩ Passive Monitor Controller ⟩⟩ JBL 305p MKiis
PaperBoat
PaperBoat
Seems complicated but interesting... I'll try it... Will EKIO work with the SONY Music Center for PC and ASIO?
