boXem Arthur 4222/E1 Amplifier Review
Rate this amplifier:
    Votes: 9 2.4%
    Votes: 11 3.0%
    Votes: 62 16.8%
    Votes: 288 77.8%
This is a review and detailed measurements of the boXem Audio Arthur 4222/E1 mono power amplifier. It was sent to me by the company and costs €1,490.00.
The design is quintessential European with gray body and colorful front panel which I like. The only power button is on the back:
Fortunately you have trigger input so you can set it to power up when the source turns on. Three gain settings are provided which is very nice. Unlike some amps in its class, it has both XLR balanced and RCA unbalanced inputs.
The amplifier is class D and is based on Purifi 1ET7040SA module.
EDIT: amp is 4222, not 4215.
boXem Arthur 4222/E1 Measurements
I started with the input gain set to low:
This is superb performance and easily lands the unit in our top 5 amplifiers ever tested:
To get to full power with low gain, you need 9+ volts of input. So I set the amp to medium gain where 4 volts is enough to push it into clipping. Performance thankfully remains the same:
Signal to noise ratio is exceptional:
Low distortion translates into very high distortion-free dynamic range:
Frequency response is load independent and quite flat in audible band:
There is healthy amount of power available into 4 ohm:
BoXem Arthur 4222E1 Monoblock Amplifier Max and Peak Power into 4 ohm Measurement.png
Company asked me to also test 2 ohm performance:
We get the same low noise and distortion into 8 ohm:
There is some "ballooning" of the distortion curve at higher frequencies:
BoXem Arthur 4222E1 Monoblock Amplifier Frequency vs Power into 4 ohm Measurement.png
As noted, this is still very good for class d amplifier.
Building on solid foundation of Purifi amplifier module, the 4215/E1 delivers the goods with tons of power with very low noise and distortion. And it does so in a compact and attractive box with nice feature list. Not sure what else there is to ask for. Yes, the price is a bit high but you are getting European build and support so you need to value that as well.
It is my pleasure to recommend the boXem Arthur 4222/E1 amplifier.
Axo1989
Sydney
Very nice implementation of the 7040 from Boxem. Good to see performance into 2Ω. Will the amp be kept or returned?
Very nice implementation of the 7040 from Boxem. Will the amp be kept or returned?
Returned. He has asked me multiple times to send them back!!!
JSmith
Algol Perseus
Plus it still has;
Plug your audio source (with volume control), your speakers, the mains cable, switch on the mains, and forget your amplifier. The automatic on/off function detects the presence of sound at the input and automatically powers on the amplifier. After 10 minutes without sound at the input, the amplifier sets itself in standby, allowing an ultra low power consumption when not in use.
If you are equipped with electronics featuring a trigger function, 12V trigger in and out connectors are also available.
Nice to see one of the Purifi boXem's tested here Amir, performance and build quality is excellent.
Nice job @boXem | audio.
JSmith
ririt
France
This is a review and detailed measurements of the boXem Audio Arthur 4215/E1 mono power amplifier. It was sent to me by the company and costs €1,490.00.
boXem Arthur 4215/E1 Measurements
It is my pleasure to recommend the boXem Arthur 4215/E1 amplifier.
I am glad to see that this Boxem amp based on a Purifi module displays stellar performances. It is a bit pricey but the stereo version dsiplays a much more competitive price while losing some features ( trigger and RCA inputs). However the autosense option ( automatic on/off switching ) and xlr inputs are still provided.
Congrats Boxem!
Axo1989
Sydney
Are those model numbers correct? I can see 4215/E2 and 4222/E1 (which looks like the mono 7040) both at €1490 on their product pages.
ririt
France
Are those model numbers correct: I can see 4215/E2 and 4222/E1 (being the mono 7040) both at €1490 on their product pages?
Yes you are right. This is the reference provided by their web page. It is a bit confusing….Maybe Boxem can confirm which model has been tested by Amir and Amir, if needed, should correct the title of the review.
Matias
São Paulo, Brazil
Awesome amp!
Axo1989
Sydney
Yes I noticed both web pages call themselves 4215. The text repeats 4222 consistently so I'm guessing that's it. It's not a drama either way, I'm sure it will get sorted.
ririt
France
Yes I noticed both web pages call themselves 4215,.The text repeats 4222 consistently so I'm guessing that's it. It's not a drama, I'm sure it will get sorted
For sure no drama…especially on a sunny sunday morning here in the south of France! I am sure that Fred (the french Boxem´s owner) and Amir will fix it.
VintageFlanker
Paris
Thanks, @amirm ! However, it is indeed Arthur 4222/E1. Not 4215.
Excellent job as usual, Fred ! :cool:
But I would have honestly expected a bit more... power...
So, 700W <1% THD+N. Great. It could be cool if this 2 Ohms load comes with any amp review, @amirm. ;)
BoXem amps do have an auto-on feature as well.
capslock
Now what is the 1ET7040SA module? The Purifi Audio homepage still shows only the 1ET400A module. Since I found no datasheet or even an announcement, I have no idea that niche this module is supposed to fill.
Is this taken from the Hypex playbook of introducing the NC400 flagship first and then following up with the slightly downspec'ed NC500OEM?
