- Joined
- Jun 5, 2020
- Messages
- 4,847
- Likes
- 3,773
Are you sure? Pull up chart on P3ESR please! All Buchard has is more bass.
Yeah I do like the house sound of Harbeth. It's called music.
I thought you didn't care about measurements?Yeah I do like the house sound of Harbeth. It's called music. I never heard Buchardt but nothing intrigues me here! I am perturbed about that spike at 518 hz. No thanks!
There’s more spikes in Harbeth speaker. The 30.2 has spikes at literally every frequency between 200-300hz...Yeah I do like the house sound of Harbeth. It's called music. I never heard Buchardt but nothing intrigues me here! I am perturbed about that spike at 518 hz. No thanks!
Anyway, that spike was found to not be audible.
@Maiky76 can you do an EQ for this one? Thanks!
Buchardt S400 APO EQ LW 96000Hz
March012021-134217
Preamp: -2.8 dB
Filter 1: ON HPQ Fc 41.7 Hz Gain 0 dB Q 1.13
Filter 2: ON PK Fc 96.2 Hz Gain -1 dB Q 1.9
Filter 3: ON PK Fc 507 Hz Gain -1.35 dB Q 4.9
Filter 4: ON PK Fc 908 Hz Gain -1.08 dB Q 4.76
Filter 5: ON PK Fc 1123 Hz Gain 1.01 dB Q 4.9
Filter 6: ON PK Fc 2300 Hz Gain 2.67 dB Q 3.2
Filter 7: ON PK Fc 5594 Hz Gain 1.6 dB Q 5.08
Filter 8: ON PK Fc 15258 Hz Gain 2.2 dB Q 1.83
Buchardt S400 APO EQ Score 1 96000Hz
March012021-133729
Preamp: -2.7 dB
Filter 2: ON PK Fc 97.2 Hz Gain -1 dB Q 1.69
Filter 3: ON PK Fc 520 Hz Gain -2.2 dB Q 10.7
Filter 4: ON PK Fc 887 Hz Gain -1.02 dB Q 3.76
Filter 5: ON PK Fc 1118.5 Hz Gain 0.69 dB Q 7.64
Filter 6: ON PK Fc 2306 Hz Gain 2.67 dB Q 3.2
Filter 7: ON PK Fc 5744 Hz Gain 1.31 dB Q 3.3
Filter 8: ON PK Fc 9512 Hz Gain -1.13 dB Q 0.88
Filter 9: ON PK Fc 15259 Hz Gain 2.2 dB Q 1.83
Thank you! It looks like the changes are modest.Some improvements
I have tried this and the only benefit I got from it was a more centered image for someone sitting to my left or right. Time/intensity trading really works. But I lost soundstage width and it was a bit less enveloping so I didn't prefer it for me sitting in the captain's chair. Most people tend to find they prefer these toed in slightly but to still see the inside face of the speakers (speakers crossing behind you). If you're at 15-30 degrees you'll get the flattest response per the spinorama. The direct sound is pretty flat with the sound power showing the output to the sides of the speaker dipping at the crossover. That is why I would be very hesitant to boost the crossover region based on the in-room response – you'd be boosting the direct sound above neutral.Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location to get the axis closer to the LW on which the EQ is designed as seems to be the speaker...
I would be curious if boosting the crossover really brings audible benefits. Due to the directivity mismatch, it is usually not recommended. In fact, Audyssey implemented the Midrange Compensation to prevent their EQ from boosting that range, but they acknowledge it won't match every speaker profile so you are free to carve out your own.
I would also like to draw a résumé here.
Up to now there has been no clear proof for the resonance around 500Hz - the near field measurements of @napilopez suggest that it is interference between the bass-midrange driver and the passive radiator, only the course of the summed frequency response measurements does not show this clearly (probably the phase position would have to be adjusted a bit).
In order to avoid that, due to the lack of unambiguous evidence, Buchardt owners assume that vibrating cabinet side walls are the cause after all and start to reinforce the loudspeaker cabinet with inner struts, another simulation shall provide the missing piece of the puzzle (That sounds like I think Buchardt owners are stupid, I don't, but I needed a dramatic hook ).
For this purpose, the simulation from Post#274 is simply extended by the passive radiator. This makes the Buchardt simulation look like this from the front and back:
View attachment 60673 View attachment 60674
Due to the time involved, I did not simulate the inside of the speaker, but simply let the passive radiator emit phase-inverted sound.
To simulate the resonances of the passive radiator, which are increased in sound pressure around 400-600Hz, the signal of the passive radiator was simply provided with a bandpass in this frequency range.
View attachment 60677 View attachment 60678
I think that's pretty close to what Amir measured.
It becomes even more convincing when we look at the normalized horizontal sonogram with +-180 degrees compared to Amir's (not normalized) measurement:
View attachment 60684 View attachment 60683
During Amir's measurements there were always loudspeakers that showed interference of the bass-midrange speaker with the BR ports.
With the Buchardt this is only slightly more pronounced since the passive radiator has 1.5 times the membrane area of the bass-midrange speaker.
So the case is closed and I have learned something again
Hi,
Here is my take on the EQ as asked by @Chromatischism
The raw data with corrected ER and PIR:
Score no EQ: 5.52
With Sub: 7.60
Spinorama with no EQ:
Directivity:
- Nasty resonance, still not sure when it is from
- Directivity is good but could be better given the size of the waveguide.
- in particular the XO is not that well executed
- On somewhat compromiseView attachment 115570
Better stay at tweeter height
Critical to proceed to some tests there.
EQ design:
I have generated two EQs. The APO config files are attached.
- The first one, labelled, LW is targeted at making the LW flat
- The second, labelled Score, starts with the first one and adds the score as an optimization variable.
- The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
- Not an awful lot can be done
Score EQ LW: 6.09
with sub: 8.04
Score EQ Score: 6.43
with sub: 8.38
View attachment 115565Code:Buchardt S400 APO EQ LW 96000Hz March012021-134217 Preamp: -2.8 dB Filter 1: ON HPQ Fc 41.7 Hz Gain 0 dB Q 1.13 Filter 2: ON PK Fc 96.2 Hz Gain -1 dB Q 1.9 Filter 3: ON PK Fc 507 Hz Gain -1.35 dB Q 4.9 Filter 4: ON PK Fc 908 Hz Gain -1.08 dB Q 4.76 Filter 5: ON PK Fc 1123 Hz Gain 1.01 dB Q 4.9 Filter 6: ON PK Fc 2300 Hz Gain 2.67 dB Q 3.2 Filter 7: ON PK Fc 5594 Hz Gain 1.6 dB Q 5.08 Filter 8: ON PK Fc 15258 Hz Gain 2.2 dB Q 1.83 Buchardt S400 APO EQ Score 1 96000Hz March012021-133729 Preamp: -2.7 dB Filter 1: ON HPQ Fc 41.7 Hz Gain 0 dB Q 1.13 Filter 2: ON PK Fc 97.2 Hz Gain -1 dB Q 1.69 Filter 3: ON PK Fc 520 Hz Gain -2.2 dB Q 10.7 Filter 4: ON PK Fc 887 Hz Gain -1.02 dB Q 3.76 Filter 5: ON PK Fc 1118.5 Hz Gain 0.69 dB Q 7.64 Filter 6: ON PK Fc 2306 Hz Gain 2.67 dB Q 3.2 Filter 7: ON PK Fc 5744 Hz Gain 1.31 dB Q 3.3 Filter 8: ON PK Fc 9512 Hz Gain -1.13 dB Q 0.88 Filter 9: ON PK Fc 15259 Hz Gain 2.2 dB Q 1.83
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Some improvements
The rest of the plots is attached.
