Carver M-1.5t Review (Vintage Amp)
Rate this amplifier:
    Votes: 102 48.8%
    Votes: 83 39.7%
    Votes: 13 6.2%
    Votes: 11 5.3%
This is a review and detailed measurements of the Carver M-1.5t vintage stereo amplifier. It was kindly sent to me by a member.
The M-1.5t came in an era where rack mounting meant serious business. As a Carver (receiver) owner myself, I remember all the advertising for the M-1.5t. Oddly, there is no power switch anywhere:
I got a chuckle seeing that monster cable tag:
And found the power specs ridiculously complicated but I am sure was appreciated by the aficionadas of the amp:
The front LEDs don't light up until it is putting out a lot of power. I liked the top LED which was the limiting lights and nice protection circuit which kept the unit on no matter what.
This amp was part of Carver "Magnetic Field" amplification line which varied the power supply voltage to substantially reduce the size and weight of the transformer. As a result, the unit ran quite cool, maybe a bit warmer than modern class D but still, impressive for the time.
The owner has replaced the capacitors in this unit. Otherwise I think it is untouched.
Carver M-1.5t Measurements
I can see why there is no power switch as the amp did not stabilize for the 14 minutes I measured it:
The level of instability is quite large, going beyond 10 db variation in SINAD! I am used to seeing 1 or 2 dB, but nothing at this level.
When I had the unit connected, and before I fed it signal, I could see constant switching noise:
Not sure what that is about.
Here is our dashboard at 5 watts with 1 kHz tone:
Third harmonic dominates distortion profile and with it, SINAD (relative sum of noise+distortion). Average SINAD of 55 dB for both channels is far, far below that median for all amplifiers I have tested to date (around 79 dB). On top of distortion, we have massive pulse train which oddly starts at 40 Hz. So definitely not very clean.
SNR though was better:
Frequency response was nice, flat and extended:
Crosstalk was "OK:"
Multitone shows more than usual increase in distortion vs frequency:
Front of the unit says it has low feedback which is likely responsible for this.
Claim to fame is lots of power so let's see how it does:
We see a distinct jump in distortion at around 66 watts which must be when it switches to higher power supply voltage. Allowing for copious amount of distortion, there is good bit of power at 273 watts. Here is the same at 8 ohm:
Now let's test peak performance:
Carver M-1.5t Measurements Max and Peak Power into 4 ohm Vintage Stereo Amplifier.png
There definitely is a lot of headroom, allowing power to almost double! The 600 watt number and such must have been at higher distortion levels than what I allow.
Testing for frequency sensitivity we again see the higher distortion at higher frequencies:
Carver M-1.5t Measurements THD vs Power vs Frequency Vintage Stereo Amplifier.png
20 Hz performance also dropped with rising distortion at just 20 watts.
Finally, here is the ultrasonic spectrum:
It is nice to test products that were iconic during my youth with state of the art measurements that didn't even exist then. Using that, we see that in noise and distortion the M-1.5t is outgunned by vast number of amplifiers today. However, it produces copious amount of power which would have been even more impressive then. The efficiency rivals class D amps today which was unheard of at the time.
Looking online, I see that non-upgraded but working units go for $500 or so. They seem to be a decent alternative to pro class D amp if you have a soft spot in your heart for vintage amplifiers. :)
PeteL
Someone correct me if I'm wrong, I don't find the exact age of this in the review, but I think tha between .12% and .24% THD was not very good then and yes they could measure that. Even just half of that could have been decent if they matched. Yes good power. We don't know if it as been serviced since? The specs are yes a bit weirdly worded, but the are generally better than this.
As I noted in the review, owner had sent it in to have the capacitors upgraded.
LTig
Europe
Power wise this amp is not in spec. These are 350W at 8 Ohm and THD ≤ 0.5% which is 46 dB. At that level your curve has barely exceeded 220W.
Walter
This is actually more disappointing to me than the Crimson 275 debacle, as this amp was definitely within Bob Carver's supposed area of expertise, and from a time when he was running the company. Does anyone know of any tests that were run at the time this was released, to see if the performance has somehow degraded over time? I'm rather glad I didn't have the money back then to buy one.
tomtoo
Germany
Sry, maybe i just not read, but at what year came this to market?
respice finem
"Million $" looks, "headless" performance - so kind of not terrible overall IMHO.
Paired with other vintage gear, probably even good enough.
Matias
São Paulo, Brazil
Ah the good old days.... Not for me.
capslock
1980s I think.
Right when Japenese companies, many of them gone or taken over now, were competing for lowest distortion and far outdid what passes for a decent stereo amp or AVR today. Small wonder engineers with Japanese semiconductor companies were worried that their products were not being used properly in the hands of Western engineers. I wouldn't be surprised, though, if this one was full of American made TO-3 dinos.
Absence of power switch is telling, too. What is the idle power consumption of this beast? Freedom is the freedom to waste. Yeah!
respice finem
For me, these are absolutely awful, monstruous measurements!!
This is why there is no (headless) panther to be seen: it has been nuked.
The problem is IMHO, should such devices be "panthered" in absolute terms, or relative to their age - this one is 42? years old. In its "market" time, ist was probably on par with most of the competition?
pma
Prague
No, the results like this have been poor regardless its age, speaking about audio performance. Horrible noise/buzz background, poor distortion behavior. 40 years ago it was possible to make same good linear power amplifier as it is today. There has been no progress in circuit design and discrete components since that time.
Vict0r
The Netherlands
Thanks for the review, Amir! The amp does look very serious.
antcollinet
UK/Cheshire
Though I hate the way they print design elements on the front panel
"Magnetic field power amplifier"
and worse
"high headroom low feedback"
AndreaT
Commonwealth of Massachusetts
I remember visiting a Hi-Fi store in Brescia in 1988 and listening to this amp…too far back to really remember the fine details but the impression was so-so. Besides, back then I could not afford it and i felt frustrated as a new graduate who made $ 2,000 a month…
