Carver Raven 350 Review (Tube Amp)
Rate this amplifier:
    Votes: 269 82.8%
    Votes: 29 8.9%
    Votes: 17 5.2%
    Votes: 10 3.1%
Loomynarty
You mean a frequency response of 20-20kHz within +/- 0.3dB!
This demographic must be blessed with super hearing. :cool:
The peak to peak difference between 2khz and ~18khz is more than 1 dB. That is definitely audible unless your hearing is damaged in those regions.
Blumlein 88
They certainly didn’t identify the ‘perfectionalist’ amplifier at the the time of the ‘challenge’. I’m sure you’re right about the advertising, although it’s weird to imagine an issue of Stereophile without wall-to-wall manufacturer ads! Notably, the team distanced themselves from the Carver Challenge, with JA claiming (as I remember) that LONG TIME listening revealed the essential differences. As in, more money inevitably buys you superior sound.
I don't remember JA distancing those claims, but was a long time ago and maybe he did. The obvious takeaway is that inaccuracy or coloration is what gave the C-J Premier amp its own sound. Not a lack of ability of SS amps. That had to be an experience that would give those involved pause. In the end, they appear to have brushed it off. I myself did testing where you series connect power amps. Load the output with power resistors and tap that with an attenuator so you get unity gain. Then you can switch the amp in and out between the source and the amp connected to speakers. Tube amps switched in were usually easy to hear and made the SS amp on the speakers sound like a tube amp. Not all, but better SS amps were really straight-wire with gain good. You couldn't tell if they were in or out of the circuit.
Xyrium
That's why metal heads use tube amps, for the distortion!
DonH56
Monument, CO
Footnote 3: I believe it appropriate nearly a quarter-century later to identify the reference amplifier as a Conrad-Johnson Premier Four.—John Atkinson
Blumlein 88
Reading back over the old article it is interesting the Rosenberg letter and its tone. The idea the high end community believe the C-J (or ML-2) were better sounding amplifiers. Since Bob Carver was able to replicate their sound, he should instead use his talents to create a 'better' sounding amp himself. Which he eventually did in the form of the Carver Silver Seven. The point that seems to be missed is the reason his cheap amp could replicate these other sounding amps is they have a colored sound. Not superior in fidelity just superior according to their tastes in coloration. So in essence they were asking Mr. Carver to create his own "superior coloration". An admission that flew over their head that high end was not high fidelity. Some over the years have defended this as being like connoisseurs of sound character. Funny that in that word connoisseurs are the word con and noise.
I believe the Silver Seven taught Mr. Carver that a colored, beautiful, big tube amp with a great story to go with it can be made and sold for a bundle of money. I cannot blame him too much for taking what the market gives. People who buy his amp are I suppose happy enough. His efforts at giving us more accurate amps and SS amps that mimic these colorations just didn't get the same notice. People need to see the glow, the glass and feel the heat to believe they are getting the real deal tube sound.
solderdude
The Neitherlands
And consider that this is measured with a resistive load. The amp has an output R of a whopping 1.7ohm so when the impedance of the speaker varies there will be even bigger variations in FR than shown here. That, and the potentially audible amounts of distortion is more than likely audible. Which, in the end, is the goal of this amplifier. To sound different from other amplifiers.
Ken Tajalli
London UK
I see!
And that @solderdude and @Blumlein 88 have liked it, interesting.
So here is a question to everyone:
- the worst case scenario (on the worst channel) is a slow rise to 0.6dB at 10kHz to about 1.2dB at 18kHz. Regardless of other failings of this amp, what demographic can even detect such a HF rise? Or benefit from it, to the point of buying it? (that was the point, if I recall)
I still say a demographic with very very good hearing! don't believe me? dial a 1.2dB parametric equaliser setting at 18Khz (Q possibly 0.2), and test it for yourself.
I am not saying it is beyond audibility! we are talking demographic of people with good or poor hearing.
This amp has multiple serious flaws! this minor, zoomed in FR discrepancy is neither here nor there.
It's like having a go at Hitler, because he was short!
solderdude
The Neitherlands
Your question is not very relevant as the measurement is made using a resitive load.
With a 1.7ohm output R and varying speaker loads the tonal changes made by those aspects are larger.
And yes, 18kHz is only interesting for young audiophiles. + 0.6dB at 10kHz is detectable, certainly when the lift is wide and one can compare directly.
Again this is with a resistive load which the vast majority of speakers is not.
This amp is purpose designed to sound different and measurements (specs as Amir did not measure Rout) say there is plenty of reason Rob (or whoever designed it) did a good job doing that. Whether I, ASR members or owners like those changes is another thing and is very speaker dependent as well.
Just put a 1.8ohm 5W resistor in series with your speaker to find out. In the case of this amp (with the as 'room sensing BS' disguised dynamic output R increasing circuit) the 1.8 ohm may even be too small.
Ken Tajalli
London UK
You missed the bit about " Regardless of other failings" , "demographic" and "this amp has multiple flaws" .
The original post was that a certain demographic would buy this amp because it has a rising HF response that matches their hearing loss.
I begged to differ!
I didn't ask if it was "detectable" by golden young ears, did I?
I asked what demographic can hear and benefit from such an FR response?!
I know about the high output impedance, so if the speaker should have a falling impedance at high frequencies (wait for it...) it would correct the amp!
if it is a rising impedance, then it wouldn't. In either case, that was not the question.
Blumlein 88
The original message was that a certain demographic would buy this amp because it has a rising HF response that matches their hearing loss.
I begged to differ!
Your question is impossible to answer. Will this amp with that slow wide rise sound slightly different than a flat amp? Yes. Who likes that? I don't know, and there are many more things beyond just that going on as you said. I haven't said this is significant to fix anyone's hearing loss. So don't know what you are trying to pin down.
SIY
Alfred, NY
The sound differences will potentially be marginally detectable in a direct, rapid-switching comparison. But on it's own? Dubious.
What sells this amp is appearance and story, the sonics are far more likely either an afterthought or not really given any thought. Trying to grasp at 1 dB errors or mediocre distortion performance as some are doing misses the point of the product.
fpitas
Northern Virginia, USA
Chances are, the only thing this amp competently corrects is Carver's bottom line.
solderdude
The Neitherlands
That small particular rise is not in any relation to the considerable different drop in response caused by aging or abuse.
When a speaker has a lower as well as higher impedance the amp will change it's output voltage but in the wrong direction. So an impedance hump will ensure the output voltage rises even higher which is exactly what is not desirable.
A lower impedance will result in a lower than desired/intended output voltage so also exactly what one does not want (in the light of signal fidelity).
Ken Tajalli
London UK
As an ex OTL amp user, I am well aware of that.
Impedance hump, won't change the output voltage that much, am I right?
An impedance dip does reduce the output voltage
fpitas
It's just a voltage divider. formed by the amp output impedance and the speaker impedance.
solderdude
The Neitherlands
For an amp with a low output R it won't
For an amp with a fixed (usually also frequency dependent) output Z it will depending on the actual load.
With this particular amp it is even worse than a fixed high output R because of the added current feedback on top of the overall (voltage) feedback.
Ken Tajalli
London UK
Now we are getting into "this amp has multiple flaws" territory.
Did you also miss the bit about Hitler being short?
fpitas
This being the internet, there are traditional ways to approach that. "You know who else had multiple flaws?" is a time-honored one.
