Denon DN-200BR Professional Bluetooth Receiver Review
Rate this balanced Bluetooth receiver
    Votes: 28 25.9%
    Votes: 65 60.2%
    Votes: 11 10.2%
    Votes: 4 3.7%
This is a review and detailed measurements of the Denon DB-200BR professional balanced Bluetooth receiver. It was kindly drop shipped to me by a member and costs US $129.
The form factor and functionality of the DB-200BR is perfect. While consumer gear uses SMC connectors for BT antenna, we have the more popular BNC connector:
The antenna puck is magnetic which should make it easy to slap on the top or side of the rack.
As you see we have balanced XLR output which is very hard to find in consumer bluetooth receivers. The last one we tested from Kali had very poor noise performance. Hope is that we do better here.
Denon DB-200BR Measurements
The unit only advertised SBC codec which is better than aptX but not as good as LDAC. Using that, here is our dashboard with volume at max:
I was disappointed that with max volume, we could not get more than 1.6 volt. This is about 6 dBu which beats the 4 dBu spec but still, for a professional product we need to get 4 volts. Let's reserve judgement on the SINAD until we test another product to compare to (see below). The really good news is that we get 15 bits of dynamic range which easily beats the 12 bits of Kali:
Denon DN-200BR Balanced Professional Bluetooth Receiver Dynamic Range Measurement.png
To see how good we could do, I pulled off the recently reviewed Topping D70 Pro Sabre DAC and drove it with the same SBC codec:
SINAD is identical which indicates the problem is there, not in the implementation post the BT receiver. The topping though outputs 3.3 volts which while still shy of 4 volts, is far better than the 1.6 volt that DN-200BR produces. This lets the D70 Pro to easily eclipse the dynamic range of the Denon:
But this is not the best the Topping can do. Let's switch to LDAC BT DAC:
This matches our testing before showing superiority of LDAC codec in the way it essentially produces transparency for high res audio. Dynamic range is also sharply increased, again matching wired connection:
This is with LDAC in "best effort" mode with a distance of a few feet from my Samsung S23 Ultra streaming to it using Roon player.
The DB-200BR nails the functionality and form factor for a professional Bluetooth Receiver. Alas, it is a let down with its low output voltage which doesn't even rise to what we like to see over RCA let alone XLR. Given that handicap, it still does well with 90 dB dynamic range. It would be nice to see a box like this support LDAC so we get full transparency for people who want to use it in their home scenario (not going to matter for Pro).
Personally I can't recommend the Denon DN-200BR due to its low output voltage. But if that is not an issue for you, we have a performance solution here within the bounds of SBC codec.
IAtaman
Right, the relative height and frequency of the spikes seems to be identical between two devices indeed. Maybe they are where the sub band boundaries are? I will try to find and read the specs. Thank you.
Talisman
Milano Italy
Difficult to make sense of this product, by now there are many LDAC bluetooth receivers with digital audio output, to be able to comfortably use the balanced outputs of your dac.
The limited support only to the SBC speaks to us of an obsolete product.
No reason to exist.
Thanks Amir
In what situations do pros use a unit like this? What is the intended user case?
For home use would be to add BT capability to a DAC that doesn't have it. That way, you can quickly stream some tunes to it.
For pros, I am not sure but I am assuming it allows someone to push their music to their system without wired connectivity.
If i didn't know any beter i would have said that this line is AI generated :p.
That's what you get for a review done at 1:00am. :) Corrected. Now I am going to sleep....
PeteL
Professional lines of products refer to the distribution channels. It is not necessarily that the pros will use it, although they can and they will, but it's the professionals that will install it. When an audio-visual Integrator gets a contract to install an audio system in any public facility, they don't run to best buy to purchase a BT Receiver. This will be in the catalog with some Audio-Visual pro distributors, the same places they will purchase the rest of the equipment. Think any place where background music is needed Restaurants, stores, Gymnasiums, dance schools, office spaces, anywhere really. It needs to be balanced because long runs of cable may be needed since the amps and mixers may be far away in an electrical closet and may feed all the speakers in the building.
Rja4000
Liège, Belgium
I guess that's to allow broadcasting background music or content without having to deal with connectivity variations/complexity.
It's probably not worse than a direct PC sound card.
Connection stability and universal CODEC are more important than higher performance for this kind of use, so SBC is a logical choice, I suppose.
The level is also probably not an issue for this type of use, since it will most likely be connected to a balanced inputs pair on a mixer, which provides a large input level range.
Stuttgart, Germany
Wait, what? I thought aptX is vastly superior to SBC, the quality is only second to LDAC anf LHDC.
Michou
I don't think the following statement is correct: "The unit only advertised SBC codec which is better than aptX but not as good as LDAC."
SBC clearly stands at the bottom of the foodchain as far as Bluetooth codecs are concerned. AFAIK, the order is from worst to best SBC < AAC < AptX < LDAC.
Ken Tajalli
London UK
This comment is about LDAC and other codecs, not the devices.
In standard measurements, LDAC seems transparent, and indeed it is the best of BT codecs and Topping implementation is second to none.
But . .
LDAC is not that reliable over distances of few meters. This is as much an issue with transmitter as it is with receiver .
Also, subjectively, any lossy codec robs the sound of some life and vitality. LDAC does it the least, but does it never the less.
LDAC on my Topping DX7 pro is excellent, but it is no match for its direct inputs. So I never use it!
instead, I stream over wifi to the PC that is connected direct to it.
I suppose the only advantage of SBC BT is its low latency, and reliable connection.
What's the latency on LDAC ?
DavidK442
But . .
I’m pretty sure that Amirm’s test results show that LDAC, on the Topping at least, does not rob the sound of vitality or life.
sarumbear
No reason to exist.
There are various BT connected musical instruments that needs to catered for at live events or in recording studios.
There’s an audio world outside your living room…
