Emotiva RMC-1 AV Processor Review
This is a review and detailed measurements of the Emotiva RMC-1 AV Surround Sound Processor (for home theater). It is on kind loan from a member. The RMC-1 costs US $4,999 from the company direct. It is part of a new generation of high-end processors sporting 16+ channels of audio.
I like the serious, ready to go in an AV rack look of the RMC-1:
Emotiva RMC-A Home Theater Surround High-end Dolby Atmos Processor Review.jpg
Despite the massive size, it is not too heavy to move around. The blue LED (OLED?) is a good choice for a dark theater.
The back panel sports the connectivity of a modern processor, leaving behind all the legacy connectors (component, composite video, etc.):
Emotiva RMC-A Home Theater Surround High-end Dolby Atmos Processor Back Panel Connectors Review.jpg
The good news unfortunately stops once you go past the mechanicals and look of the unit. Boot time is long and even waking up from standby is slow. Cycling inputs through inputs can be painfully slow as the unit seemingly tries to lock onto unused inputs. Just about every change produces a "Please wait" logo on the right. I don't mind things taking a bit longer but not being to navigate the UI makes no sense to me.
The remote control is a substantial metal box. It makes the buttons easy to find but it has no backlight. How can you use this in a dark theater??? Best to invest in a control system or unified remote than use the included one.
The owner had installed version 1.7 which was the last official version. That version proved very buggy with serious performance problems to boot. A little bird told me there is a version 1.8 that is a "total rewrite" and gave me a link to install. That did improve things including a few serious performance problems. He also passed on the message that the company wanted to talk to me before I publish the review. So I fired off an email to them last Friday and sat on the review until now (late Monday). No response back. :( This being an expensive and large unit that is taking a lot of space in my lab, I decided to proceed regardless. If the company has feedback, they are welcome to share it now.
There are still some operational bugs such as Reference Stereo not producing audio most of the time. I would have to switch back and forth to direct or even restart the unit to get it to produce audio.
Another disappointing thing is the OSD (on-screen display). Instead of using the entire display and show the unit status at a glace, it just replicates the two line menu. Really? Talk about taking a poor shortcut here. The menu as is, can be tedious to use. For example to activate a mode, you don't just push the center/enter button. Instead you have to move to another suboption to select a checklist. Never seen anything like this.
Since everyone uses these processors with HDMI input, I tried to use that output from my PC and yet again failed to get any output as with the last high-end processor I tested. I went through three video outputs from my PC (Nvidia, native Intel and a cheap USB to HDMI desktop extender) and three different monitors. All monitors would show video directly from the PC but once routed through RMC-1, nothing would come out. Windows would detect that RMC-1 was connected and was the "display type" but as noted, I could not get any video output. I am wondering if latest versions of HDMI chipset in these processors has broken compatibility with PC ecosystem somehow. I will keep trying to diagnose this problem. For now, all my testing is performed using AES/EBU digital input (balanced version of S/PDIF).
EDIT: An updated Version 1.9 firmware fixed some core issues that were dragging performance down. Please see here: https://www.audiosciencereview.com/...a-rmc-1-av-processor-review.11673/post-344170
AV Processor Audio Measurements
As usual, our goal here is to check the main audio pipeline to see if it is well engineered. It starts by feeding the unit a 1 kHz tone at 24 bits and see how low the distortion+noise is. The RMC-1 uses a high performance DAC from AKM:
Here is the specs for AKM4490:
This is what I get when tested in Reference Stereo mode which bypasses all DSP including bass management:
Emotiva RMC-A Home Theater Dolby Atmos Processor Reference Stereo 4 Volt Audio Measurements.png
SINAD in this display is the same as THD+N expressed in dB and positive. This means that the AKM4490 datasheet's SINAD is 112 dB yet we are just getting 92 dB out of RMC-1. 20 dB of noise and distortion is left on the table due to suboptimal implementation.
Switching to Direct mode which leaves bass processing active reduces performance even more:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt Audio Measurements.png
And it is not just harmonic distortion and noise. Notice the dual spikes around 300 Hz. What the heck are these? Their frequency changes with sample rate so it has something to do with that. But what? Notice that they exist in both Direct and Reference Stereo.
Here is just the FFT by itself, this time with 48 kHz sampling (which is very common in video content):
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt 48 kHz sampling Audio Measurements.png
This is a seriously broken implementation of AKM4490. Since most people want to use bass management, you are losing nearly 27 dB of performance. Engineers often kill themselves to squeeze 3 dB better performance out a design so 27 dB is huge.
Anyway, going with the better number of the two, here is where the unit ranks:
And within 18 processors and AVRs tested so far:
I know, you are thinking the output level is too high so let's look at a new test that shows us the distortion+noise relative to output level:
Emotiva RMC-A Home Theater Dolby Atmos Processor SINAD vs Output Level Sweep Audio Measurements.png
This is a head scratcher. The Reference Stereo mode (green) improves with increasing output level to 4 volts. The Direct mode works backward, besting the Reference Stereo at lower output levels but then declining at full 4 volts. Some kind of gain scaling must be behind this odd behavior. Either way, our 4 volt output is not stressing the unit. It can't produce better than 92 dB SINAD no matter which mode or output level you choose.
You want to get depressed? Check out what happens when we measure intermodulation distortion relative to input level (digital sample values):
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt IMD Audio Measurements.png
Sigh. We start with excellent, low noise performance rivaling our good desktop DAC reference (Topping DX3 Pro ~$250). But then at just -35 dB, distortion takes over and the RMC-1 loses to a little phone dongle from Razor which retails for US $25. Why, why, why???
Hey, maybe it handles jitter well. Let's find out:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt Jitter Audio Measurements.png
Nope. Nothing other than main spike at 12 kHz should be there. Instead we have an array of sidebands indicating very clear, and correlated jitter component. As you see, the jitter remains whether I used AES or Optical input.
There are some bright spots like dynamic range:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt Dynamic Range Audio Measurements.png
Linearity could that too except that just sitting there, it changes its performance from near excellent to a step below:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt Linearity Audio Measurements.png
Even filter performance is odd:
Emotiva RMC-A Home Theater Dolby Atmos Processor DAC Filter Response Audio Measurements.png
What is with that high level of ripple? I could not find a filter mode in AKM4490 that has this kind of response.
Turns out we are not done depressing ourselves. Check out THD+N versus frequency:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt THD+N vs Freq Audio Measurements.png
A $99 DAC is in dashed blue. Forget that we don't match that curve. Notice how distortion rises with lowering of frequency. Best DACs have no frequency dependency. Those that do have rising distortion with frequency as you see in Blue. But the RMC-1 has the opposite problem, typically indicative of poor power supply design. In Direct mode distortion rises to whopping 0.1% THD+N! That is a 25 dB drop from our reference 1 kHz tone we used in the dashboard!!!
Let's dig into this further:
Emotiva RMC-A Home Theater Dolby Atmos Processor SINAD vs Output Level Sweep 20 Hz Audio Measu...png
We see that distortion rises with level (lower worse). Compare this with the graph I post earlier that was at 1 kHz. The variation there was much smaller.
We can see the frequency dependence by looking at the full spectrum:
Emotiva RMC-A Home Theater Dolby Atmos Processor 4 Volt 20 and 10 kHz FFT Audio Measurements.png
Notice how the harmonic peaks of the 20 Hz (in red) are much higher than those of 10 kHz tone (in blue).
This is a stunning failure for a high-end AV Processor. Usability is not great, and bugs are easy to hit on. The worse news by far though is the measured performance of the pipeline from digital input to analog output. Despite using a premium DAC chip, the measurements paint a very ugly picture. This is a hardware design problem and not fixable with firmware updates and such.
Coming on the heals of another failed high-end processor, I am starting to think there is not anyone performing these basic performance checks before the design is released to the public. And not enough expertise is applied to key analog (and gain management) subsystem.
Even the DSP processing seems faulty. Why lose so much performance because you turn on the DSP? IN this day age, there should be no issue whatsoever to use high resolution internal representation to avoid screwing up 24 bit audio samples. Now, in a $300 AVR maybe that is a stretch but in a $5,000 processor?
Really, these companies would be in better shape if they bought a $1 DAC that has a SINAD of 95 dB and get that kind of performance. The $9 Apple dongle does that. Why put in an expensive DAC chip and incur the huge hit to the BOM (bill of material) if you are not remotely able to get its performance out the door from the XLR connectors?
If no one is left in the industry, ask me to test for heaven's sake. I take no joy in writing these reviews. Both companies know who have built these high-end processors know where to find me. I am not looking for work but please, one of you needs to build a decent high-end processor that we can be proud of. Don't let this industry sink backward anymore. With video processing no longer needed or included, let's get audio right.
Anyway, it should be obvious that I cannot recommend the Emotiva RMC-1. Buy it for features if you can live with its bugs. But don't think you have a high-end Audio product.
Had tons of rain yesterday and winds. Woke up this morning with one of our massive 40+ foot trees had fallen across our drive away and onto poor neighbor's roof! Everyone is safe thankfully but I am needing good chunk of money to become happy again after dealing with this all day. So please donate what you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
gags11
Thank you for the review, Amir!
I have been and am sure many others too are interested in your AV processor reviews. I do have a naive question though. Why are we measuring these at almost 4volt output? In 2 channel music, 4 volt output may make more sense, but in a theater processor? Don’t most amps used in a theater systems have sensitivity at around 1-2 volts? Would it make more sense to know SINAD at outputs that these processors will be used at? Am I missing something?
Thanks again for all the work you do and have done for audio enthusiasts. I have learned more from you and this site in the last year than I had 10 years prior to that.
gags11
PS
If this were to be used with Emotiva’s own XPA-7 amp, which has input sensitivity of 1.5 volts, one would think measurements at 3.8 volts output would be irrelevant, wouldn’t it?
doodlebro
Please continue digging into performance with features like bass management enabled!
A simple DAC with no volume control produces 4 volts (usually) with balanced outputs. Therefore to see if an AV processor has the same quality implementation, we also need to ask it to produce the same output voltage.
To address your point however, I added the test of output voltage versus SINAD:
You can see that in Reference Stereo, having more output helps this processor (green). With others tested so far, they do get worse with higher output.
From here on, you can use the graph above to figure out in your application what you are facing. I am showing about 0.5 volts to 4 volts output range which should cover most amplification needs/gains.
PS
As I just explained, I am showing the performance across wide range of outputs now. This processor is actually not that sensitive to output voltage. To wit, at 1.5 volts SINAD drops 1 dB in Reference Stereo.
gags11
Haha, did overlook the graph above.
Thank you!
the reason I mentioned this, was when I read Audioholics review of the Yamaha CX-A5200/5100 processor, they mentioned the SINAD at 1 volt was 105db, but dropped sharply when output levels were increased.
DonH56
Monument, CO
Wow, epic fail from a "flagship" processor! :( The good news is that I did not trade in my XMC-1 but went a different route (SDP-75, but after nearly four months still have not found time to install the thing and try to set it up!)
You can select HDMI 1.4 vs. 2.0 in the setup menu for the inputs on my XMC-1; if that feature is in the RMC-1's FW, it might help connecting to your PC?
Noob
One would be better off getting the XMC even with its freakish linearity issue.
Maconi
Even though there is a rabid Emotiva following, I feel like this review will be received with less drama than the HTP-1 review. Even if the unit measured fairly well (which it didn't), all the known Emotiva bugs/issues would prevent it from being usable for most people anyway.
Between the two (I've owned the RMC-1, past tense) I would go with the HTP-1 currently (mainly due to lack of XLR/Dirac/Atmos options honestly). I'm still holding out to see how the JBL SDP-55 tests, but if the Arcam AV40 (which the SDP-55 is based on) is anything to go by then I'm not very optimistic about it.
LightninBoy
St. Paul, MN
What a disaster. 5 grand for a buggy processor with bad audio that will be obsolete in 3 years. And they wonder why HT is dying. Hell, it even makes me want to just buy a soundbar and be done with it.
digicidal
Sin City, NV
If that SDP-75 isn't doing anything... maybe it would like to visit Washington? Seeing as how it's still pretty cold in Colorado, I'm sure it would appreciate a trip to (well near) the coast? ;) I'm sure @amirm would take it out for a nice dinner and drinks... and I know I'd love to see how it performs.
I tried that. It waits a couple of seconds and switches back to 2.0.
StevenEleven
My little $300 Onkyo AVR is looking a-o-kay right about now. :oops: I’m sure there’s a good chance it’s headless panther material and I may want better, but it kind of, well, just works, it does some cool stuff. $2 DAC chip and all. :confused:
For sixteen times more you get. . .what? I’m sorry, I can’t relate to user interface being that messed up for $5,000. That strikes me as requiring really, really basic programming and debugging skills. What, a few days’ work by one person? Okay, maybe two or three people? I mean this isn’t operating on a full-blown computer operating system, is it? It’s simple stuff, right? Am I wrong?
Maconi
My little $300 Onkyo is looking a-o-kay right right about now. :oops: I’m sure there’s a good chance it’s headless panther material and I may want better, but it kind of, well, just works, it does some cool stuff. $2 DAC chip and all. :confused:
For sixteen times more you get. . .what? I’m sorry, I can’t relate to user interface being that messed up for $5,000. That strikes me as requiring really, really basic programming and debugging skills. What, a few days’ work by one person? Okay, maybe two or three people? I mean this isn’t operating on a full blown computer operating system, is it? Am I wrong?
To quote Emotiva themselves (on the Emotiva forums), they claim they're not a "software company" so it's hard for them to release stable code for their processors. They probably should have just stuck to manufacturing their speakers and amps (although even the XLRs on their amps are wired backwards, which I'm just now finding out).
laudio
Are there any good surround processor components? Seems like most end up at the thrift for pennies on the dollar due to obsolescence anyway.
