- Joined
- Sep 16, 2019
- Messages
- 1,201
- Likes
- 2,654
- Thread Starter
- #221
Hi,
Hi,
Kudos for going though the listening tests. These can indeed be very tiring.
Your EQ score is 6.87, again it more of an indicative score than a real value.
From the curves it looks like you have EQed for a smooth PIR rather than ON/LW, is that correct?
Was your EQ adjusted by ear?
M
There you go:
All PEQ except the one LowShelf (LS) per filter.
You might want to adjust the volume as the EQed response are lower than the raw speaker.
Code:% 6.54 MX 01=[ 50.0, 1.42, 1.80,... 613.0, -0.86, 2.43,... 2050.0, -1.00, 1.92,... 1045.0, -0.67, 0.70,... LS 5740.0, -2.62, 1.71,... 11045.0, -1.45, 2.81,... % 6.58 HM 02=[ 50.0, 1.42, 1.80,... 659.0, -0.86, 2.00,... 1590.0, -1.00, 1.34,... 932.0, -0.67, 0.70,... LS 5740.0, -2.35, 1.50,... 10950.0, -1.62, 2.41,... % 6.57 HO 03=[ 50.0, 1.42, 1.80,... 377.0, 0.65, 2.57,... 640.0, -0.61, 2.00,... 1592.0, -0.70, 1.34,... 1225.0, -0.60, 0.70,... LS 5740.0, -2.15, 2.00,... 10580.0, -1.10, 3.41,...
Round #1
Same procedure. Had my GF load the filter into text files and name them and I listened to them vs one another. I asked her to doublecheck, because I could not discern any differences without doubt - she assured me they were loaded correctly. Vacation must have put me in a good mood because it all sounded good and alike to my ears. I ended this after a little over 30 minutes and went to round #2
Round #2
Since your filters sounded very alike to my ears, I simply used the first one and put it against my own made filter, and the original uncorrected C208.
Again, it was very hard to discern any differences - there were a few times in which one of the test candidates sounded a little 'sharper' than the other two. After another good 30 minutes I called it a day - I suspected correctly that the slightly sharper sounding file was the one without any filters loaded, and turned out I was correct. I have not loaded your files into REW yet, but looking at the filters now I suspect they are all very similar.
If you are interested, here are my filters - I may replace it for one of yours, I'll have a look in REW what's going on exactly
Any remarks so far on your end about our testing here? Is there any correlation between my subjective impressions and your filter design criteria?
