Fosi Audio BT20A Pro Amplifier Review
Rate this stereo amplifier
    Votes: 3 1.0%
    Votes: 33 10.8%
    Votes: 180 58.8%
    Votes: 90 29.4%
Charleston sc
Perfect amp for my less-than-audiophile project of bypassing the defunct amp of my very old audio engine A5’s
DavidM1
What I mean is that 99% of the population listen to bad music recordings (which also have dynamic range < or << 10 dB). For them this amplifier is more than enough. And cheap loudspeakers with cheap crossovers and...
It is not appropriate for this a very good album.
Just listened to this through Apple earbuds and the Apple lightning dac. Classic blue note. Thanks! Why wouldn’t it be appropriate with this Fosi?
D
Deleted member 48726
Guest
Right, because Youtube audio equipment comparison videos are so high quality and trust worthy now
:facepalm:
I guess you somehow think the algorithm causes the sound differences?
Actually now I'm curious; do you hear a difference with headphones on?
Talisman
Milano Italy
:facepalm:
:facepalm:
I guess you somehow think that a chain made up of his listening system, plus his environment, plus his microphone, plus his adc plus youtube compression, plus your listening system are able to tell you how a "sounds" amplifier
DavidM1
Yes, they have. Because a lot of them
Cheap class D amps have problemas with HF. Usually > 1 kHz (phase). The range 1-4 kHz is very important, our ears are very sensitive and it is convenient that the frequency response is as linear as possible, horizontal or inclined, but linear.
They also suffer from a phase change, which should be constant throughout the audio range (with class A and AB it is not a problem and it is usual, the merit is that it is < 1º at 20 kHz). Also distortion tends to increase with high frequency.
If you listen to poorly produced music, without physical instruments, voices adulterated with Autotune... then those inconveniences are much less. But if you listen to a jazz quartet, folk, orchestral mass... then it does matter. The point is that today very few listen to this type of music or similar, so it is stupid to spend a lot of money on music equipment. So FOSI does very well by focusing on that 99% of the population.
In class D, the only one that convinces me is the Hypex Nilai500DIY, much more than Purifi (perhaps only better with electronic music).
Thanks for the detailed response. Virtually all of my listening is classical and jazz and acoustic realism is a high priority.
D
Guest
:facepalm:
In _that_ video I prefer the sound from the tube amp. I also mentioned earlier that we don't see the setup but that doesn't change the fact that I prefer the sound from the tube in that video. I will never claim that you can tell how an amplifier sounds on a youtube video but in THAT VIDEO I prefer the sound from the tube and can hear differences between the opamps. And that was the point. I'm very well aware that you can not tell a particular sound from a youtube. But the differences are clearly there to hear. And when I much prefer the sound from the tube amp (in that particular video on youtube) I wonder if that's the case for many others and then wonder why Fosi Audio lets that fly in a marketing point of view.
I'm very well aware that room, speaker, mic, setup and compression colours the sound. I've done about hundred of REW measurements with different speakers and subs in my own room.
Hope that clears it up.. :)
delta76
:facepalm:
Except very very few trusted youtubers you can't trust a random guy with their "comparison" videos. Especially if he is trying to prove a non sense thing (class D sounds dry etc. ) there are so much they can do to "prove" their bias.
Then you have equipment issues. And yes youtube compression
D
Guest
I'm well aware. Trust me. I've clarified above.
When that is said I do enjoy some of NRD (New Record Days) binaural videos with headphones on. That's as close as it gets AFAIC. -In that room with that equipment and my headphones.. :)
Soulsounds
How it sounds? BT20A Pro with Various Op-Amps Demonstration
I wrote:
OP249
2º OPA2604
It is surprising how well the familiar NE5532 stands the test of time.
The worst, RM4559
Hi friend
. Thanks you for that awesome video.. could you test the opa1656, the opa 2210 super-β and the LM4562NA... and compare with the op249 and the ne5532
Please!!!
Fosi Audio
what exactly does Fosi mean, Foxy?
@Fosi Audio
Good question.
We would like to define the word "Fosi" as "Full of sound & ideas".
Or extended to "Fidelity of sound immerses you in the audio world".
Do you have any suggestions?:)
JSmith
Algol Perseus
Not related to the company name... but yes. One can only assume the optimal op-amp for the circuit has been used, however I see the company actively encourages op-amp rolling. Why is that... has the optimal op-amp been used for the design, or no? If so, why this advertising of op-amp rolling? My suggestion would be to let that go and not market your devices that way, as if you imply there are improvements to be gained from op-amp rolling, then it has a negative implication for stock parts used.
JSmith
sound67
JSmith
Maybe because they realize that many so-called "audiophiles" aren't real adults but children who want to play with their toys. ;)
Same as with smart phones. All kinds of people experiment with custom ROMs even when there's absolutely no reason to do it.
Fosi Audio
JSmith
The stock ones are good enough to satisfy most users. However, we realized many audiophiles love to DIY. They are pleased to find an amp that allows them to roll the op-amps or other components to achieve their desired sound and functionality.
JSmith
Algol Perseus
In a way your reply concerns me even more now...
Up to the company, but my suggestion to not appeal to this crowd stands. No one should need to replace any parts to achieve their "desired sound" and there should be no need to tweak a completed device after purchase. I hope you don't take this post the wrong way, as it is intended as constructive criticism.
JSmith
sound67
I'm sure if they had made the Op amps (which really are snake oil IMHO) fixed items, YOU would have complained why they weren't removable. You can't please all people all the time, and people like you always find a reason to complain about SOMEthing. What they did for under 100 bucks I (so far) think is marvelous. The fact that it's even doable nowadays is a reason to rejoice.
