- Joined
- Sep 10, 2021
- Messages
- 322
- Likes
- 1,581
It's true that some amps are easy to get overheated and shut down shortly. However, we have tested the BT20A Pro strictly and it proved it can work quite stably with the 48V power supply. So basically drilling holes in its case is not very necessary. Anyway, your consideration will be taken into account. We will evaluate adding vents to it.Sure. But it still doesn't change rhe fact that there at all times is standing still air inside. This is inherently bad. Still air doesn't transport much heat. Still air gaps actually insulate. I don't get why there isn't just a handful of drilled holes.
Makes it seem like a work of haste. -Or an oversight.
