- Joined
- Sep 10, 2021
- Messages
- 15
- Likes
- 5
Looks like the GAIN switcher only works for RCA input, the XLR has fixed gain.
Accurate.Looks like the GAIN switcher only works for RCA input, the XLR has fixed gain.
I was using the V3 stereo as an example of what I tested. Based on the tests here showing enough power in stereo mode to drive both to more than enough performance, I was disappointed to find out the tests here did not reflect real life performance in a situation like this. So it was a simple test for a much smaller and quiter amp vs getting a pro amp of which I already have several for all my TR devices.Just out of curiosity, why use such an advanced and high-performance power amplifier for shakers? I think we need something very powerful and less sophisticated instead.
A professional Behringer amplifier for example or simply a Sabaj A20A 2022 which puts out 350watts when bridged. Any old Yamaha p1500/3500 power amplifier would do the job much better and can be found used for less than 150 euros
It has nothing to do with "struggle". Read my previous reply....Same curiosity here,why struggle with it and don't get a used pro-audio nice and light little beast who can throw you out of your chair?
Sound has nothing to do with it.
I see.It has nothing to do with "struggle". Read my previous reply....
I do keep a fan on them and it seems to keep cooler with the 48v 5A than the stock psu but still same results in stereo. I was just surprised how the measurements didnt deliver for this particular case.I see.
I believe at some point on this thread or on the stereo one I did mention the limitations i guessed are there given the small heat dissipation area in comparison with the specs and TI's heat dissipation plot.
So...
Measurements deliver what is there but in a very short time frame (VERY short) .I do keep a fan on them and it seems to keep cooler with the 48v 5A than the stock psu but still same results in stereo. I was just surprised how the measurements didnt deliver for this particular case.
It seems the gain of XLR is 20dB, is it what you want?Accurate.
I actually like that the XLR has lower gain than either RCA setting; allows me more room to play with source gain, preamp buffer mode selection (I have a Schiit Freya+) and volume adjustment granularity.
-Ed
I don’t think I have a very specific gain that I’m looking for, but that will work better for me than 25 or 31.It seems the gain of XLR is 20dB, is it what you want?
Maybe more gain options are needed from V3 MONO.I don’t think I have a very specific gain that I’m looking for, but that will work better for me than 25 or 31.
-Ed
I'd be slightly weary of the Sabaj A20A. I looked at these but going by some customer reviews these seem to be unreliable, especially when used as monoblocks.I was using the V3 stereo as an example of what I tested. Based on the tests here showing enough power in stereo mode to drive both to more than enough performance, I was disappointed to find out the tests here did not reflect real life performance in a situation like this. So it was a simple test for a much smaller and quiter amp vs getting a pro amp of which I already have several for all my TR devices.
Luckily in bridge mode the 07 max (and I assume the ZA3) work fine but its interesting to see that even measurements as we got here do not always tell the story for all possible uses
That Sabaj A20A 2022 looks like a nice compact one to try.
Earlier you offered a signup for a discount, and sent me vouchers for this.Yes, we'll provide that option too. The campaign will launch on April 20.
Not so sure about this.TPA3255 PBTL Mono won't gain anything (significant or useful) from 48v 5a to 10a, no benefit.
ThanksNot so sure about this.
According to the data sheet, in PBTL mono, it can do about 250W at 48V into 4ohm. This would require about 8amps.
Further, it can do more than 400W into 2ohm (say speaker impedance dips). This would need 14A.
I'd certainly like to see the power measured with a 10A supply feeding a single amp.
(EDIT - although I note that the measurements here show similar power with the 5A supply. This suggests that supply has significant short term headroom)
They are priced per amplifier, and then there are bundle deals.Hi there, new here and also looking forward to get my hands on some of these V3 mono's, to replace my Yahama AX-892 that I currently use as amp for my fronts.
@Fosi Audio : My question is whether these blocks will only be sold in pairs, or also individually? Other than a pair of these for my fronts, I would like to get an extra (single) one for my center speaker as well.
