Kanto YU Review (PC Speaker)
This is a review and detailed measurements of the Kanto YU powered computer speaker with remote control. It was sent to me for testing by the company and costs US $280 on Amazon including free shipping.
The YU is a nice and serious looking little speaker:
Like the inclusion of a waveguide around the tweeter.
Speaker is powered but crossover is passive:
Like the inclusion of AC mains and all the regulatory certifications. Form what I have read, Kanto designs and builds speakers for other makers and likely that is the reason behind proper capability in this regard.
As noted, a remote control comes with the unit where you can adjust tonality (I did not use it).
I performed over 1000 measurement which resulted in error rate of roughly 1%.
Testing temperature was around 60 degrees F.
Reference axis for measurements was the center of the tweeter. Grill was not used in either measurements or listening tests.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Kanto YU Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
The main deviation from flat on axis is the bow between 300 and 800 Hz. This is followed by a few resonances (peaking). Directivity is very good though which means this speaker will be room friendly and respond well to equalization. We can see this from early window frequency response which is very close to on-axis:
Kanto YU frequency early window response measurements powered PC speaker.png
As such, predicted (far fiend) in-room response is what we would guess:
Kanto YU Predicted in-room frequency response measurements powered PC speaker.png
Near-field response shows one of the resonances from the woofer that is not filtered out and that of the port:
CSD/waterfall shows more of them:
Distortion was surprisingly low for the class:
Not letting the 4 inch woofer play too loud certainly helps in this regard.
Beam width is nice and controlled horizontally:
Vertically you have more freedom than you typically do with 2-way speakers:
Kanto YU Listening Tests
Let me preface this section by saying that I had a terrible headache when I started the listening tests. My allergies have also gotten bad as well. So read this section with a grain of salt.
I was very impressed by how loud the YU could play. Even though I test only one speaker, it could get quite loud and when it got distorted, it mildly went into that region.
As the response predicted the sound signature is quite light. This wasn't bad on female vocals but otherwise, overall it was not very satisfying. So I pulled out the EQ to correct:
At first I did not have band 4 in yellow. As a result the EQ was a mixed bag. It warmed up the sound but it was kind of boomy. So I thought I pull down that resonances at 120 Hz and this did the trick. The sound was much cleaner. Was it a "high-end" sound? No. Was it a huge step up from cheap computer speakers? Yes.
The Kanto YU has good directivity but unfortunately delivered a response that has a large dip in upper bass/lower mid-range and some resonances. Correcting these with EQ is possible due to very nice directivity. Ability to play loud with lower than expected distortion is another plus.
Judging by standard of great sound regardless of cost and class, the YU misses the mark. I did not enjoy listening to it longer term for that reason. But if you are going from nothing or some cheap computer speaker, it surely is a big step up. So while I am too much of a perfectionist to recommend it, you may want to consider it given its functionality and price. On the former, a powered pro monitor would do much better but comes with no remote or volume control which can be a major hassle/cost to accommodate.
  • Kanto YU spinorama.zip
MZKM
Land O’ Lakes, FL
I really don’t get their naming convention, all their other models have a number after YU (I own the YU5; I agree with Amir that it gets surprising loud). It’s more expensive than the YU2 and cheaper than the YU4. From a glance, this seems to be the YU4-lite, meaning the same drivers/cabinet but only with Bluetooth and RCA input (the YU4, which is $90 more, has a phono preamp, 2 optical ports, a USB charge port to power say a Chromecast Audio to feed an optical port, nicer finish options, and comes with a 3.5mm cable).
The Kanto rep here could confirm.
YSC
Nice review as usual!
btw for the symptoms beware if that’s early symptoms of covid.. those are documented and if possible better go for a check
Thanks. I get these symptoms all the time with everything starting to bloom outside. Had my shot a week ago. Crossing fingers for a couple more weeks to put this worry behind me!
HiFidFan
U.S.A
Great review @amirm
I was interested in this speaker at one time so am happy to see a real review.
DanTheMan
These look pretty good to me for the money. You’d have to cross them over rather high, but I do that anyway on my ADAM 5”ers anyway for the same reason And they cost nearly twice this amount. These would actually have to be crossed even higher than mine, but still this is not the end of the world. These may fit the bill quite nicely for a lot of people.
YSC
I taken the first shot a few days ago too but mind you quite some friends got the Pfizer shot said the second dose feels like s__t, so you might want a few days off after;)
back to the e speaker do you have an idea what the lpf is for the sub out?
I got the J&J vaccine so one shot is all. Made me sick the same day/evening but I recovered the second day.
YSC
I do not unfortunately.
Right, I was thinking that if crossing them at around 120hz this should fix the valley a bit and get them all the bass needed, so wonders was it a 80/120hz filter
wwenze
Personally I would just shelf filter down that >1kHz and boom we have a +-1.5dB response from 300Hz and up. Then the bass part just add condiments according to preference.
napilopez
NYC
This is a pleasant surprise, and nice to see Kanto sent it to you too. The midbass scoop is an issue, but I wonder If maybe it isn't so bad if the speaker is placed right on a desk? I'm don't remember what frequency range gets boosted on a desk though so that's pure speculation.
I agree, that actually probably the simplest fix!
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
The raw data with corrected ER and PIR:
Score no EQ: 3.4
With Sub: 6.3
Spinorama with no EQ:
  • Not flat at all
  • Decent directivity
  • Port resonance and driver issue.
  • A lot of work!
  • Looks like there is a decent speaker underneath.
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • You can add two PK to tackle further the two main resonances PK 1742.0, -3.00, 10.0,... PK 3732.0, -3.00, 10.0,...
Score EQ LW: 5.3
with sub: 7.9
Score EQ Score: 5.8
with sub: 8.4
Code:
KantoYu APO EQ LW 96000Hz
April102021-134742
Preamp: -1.1 dB
Filter 1: ON PK Fc 58.3 Hz Gain 0 dB Q 1.18
Filter 2: ON PK Fc 125.5 Hz Gain -5.46 dB Q 1.48
Filter 3: ON PK Fc 982 Hz Gain -3.7 dB Q 3.96
Filter 4: ON PK Fc 1266 Hz Gain -3.46 dB Q 3.65
Filter 5: ON PK Fc 1867 Hz Gain -1.52 dB Q 4.4
Filter 6: ON PK Fc 2465 Hz Gain -2.38 dB Q 4.65
Filter 7: ON PK Fc 3475 Hz Gain -3 dB Q 3.32
Filter 8: ON PK Fc 5283 Hz Gain 0 dB Q 2
Filter 9: ON PK Fc 5683 Hz Gain -3 dB Q 1.18
Filter 10: ON PK Fc 13636 Hz Gain -2.78 dB Q 2.2
KantoYu APO EQ Score 96000Hz
April102021-134608
Preamp: -0.6 dB
Filter 1: ON HPQ Fc 57.3 Hz Gain 0 dB Q 1.18
Filter 2: ON PK Fc 121 Hz Gain -5.27 dB Q 1.17
Filter 3: ON PK Fc 1004 Hz Gain -3.7 dB Q 2.98
Filter 4: ON PK Fc 1300 Hz Gain -3.38 dB Q 4.1
Filter 5: ON PK Fc 1940 Hz Gain -1.4 dB Q 4.74
Filter 6: ON PK Fc 2492 Hz Gain -2.6 dB Q 6.34
Filter 7: ON PK Fc 3390 Hz Gain -3.54 dB Q 3.32
Filter 8: ON PK Fc 5114 Hz Gain -1.67 dB Q 2.83
Filter 9: ON PK Fc 6700 Hz Gain -2.52 dB Q 0.87
Filter 10: ON PK Fc 13640 Hz Gain -2.92 dB Q 1.66
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal, play with toe-in for flatter tonal balance
Radar no EQ vs EQ score
Significant improvements
The rest of the plots is attached.
  • KantoYu APO EQ LW 96000Hz.txt
  • KantoYu APO EQ Score 96000Hz.txt
richard12511
Hi,
Score no EQ: 3.4
With Sub: 6.3
  • Not flat at all
  • A lot of work!
Directivity:
EQ design:
Score EQ LW: 5.3
with sub: 7.9
Score EQ Score: 5.8
with sub: 8.4
Code:
April102021-134742
Preamp: -1.1 dB
April102021-134608
Preamp: -0.6 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Wow that looks incredible after EQ. Why good directivity like these speakers have is so important.
