Marchaudio P422 Stereo Power Amplifier Renewed Review
JohnYang1997
China
Good work! One thing I would point out is that, here you are using 20khz low pass filter setting which causes slight deviation in measured noise thus SINAD from Amir's 22.4khz low pass setting. On the other hand, Wolf has always used 20khz setting. So I would suggest either switch to 22.4khz low pass or if you are sticking with 20khz, it would be better to mention the difference of the filter setting and what difference it may lead to.
thin bLue
thin bLue
Reviewer
Yes, but AFAIK, RF filtering is part of the EVAL1 and most other buffers based on it.
So, good but not a major differentiator.
This is input RF filter of my P422.
As I know most of EVAL-1 based amp has no RF filter board on the back of the XLR. Am I wrong?
thin bLue
thin bLue
Reviewer
Thanks for great feedback!!!!
I got another improving points!
Technical support from competent engineer like you helps a LOT!!!!
I'll update them next time!
pma
Prague
The point is to have the RF filter as close to the input connector as possible. Best right on the pins. Otherwise the fast impulse spikes are able to bypass it on the PCB. Audio devices are often not designed according to RF design rules. They should be, because though audio signals are slow, interference signals are very fast.
thin bLue
thin bLue
Reviewer
What a kind explanation!
Thank you!
Reactions: pma
Rick Sykora
Stow, Ohio USA
March posted in another thread that the EVAL1 is “fine” with regard to RF filtering.
Have no other details to add as do not have a board on hand.
Reactions: pma
Matias
São Paulo, Brazil
My point is not about the power capacity but the distortion. The column header says at the shown power value distortion is 1%. But, it isn’t. Amplifier either shuts down or clips. In the former there is no distortion as there’s no signal, in the latter it is a value read from a chart that shows hard clipping. Neither value is in anyway an operating value.
Would adding an asterisk to the column header and a side note "* or limited by the amplifier for protection before it reaches 1% THD+N" satisfy?
restorer-john
No arguing from my side. I was speaking about general design rules to minimize RF impact.
Absolutely. Nothing groundbreaking about placing the RF filtering passive components on the input board, right on the XLR, or in the case of half a century of commercial gear, on the RCAs or right behind them on the PCB.
Rick Sykora
Stow, Ohio USA
An EVAL1 has the XLR connectors mounted directly on the board. Based on March's post, the board has RF filters.
Spocko
Southern California
Are you guys working on a premium amplifier to take on these biggies?
thin bLue
thin bLue
Reviewer
Recent reply I got from March audio would help.
Hi @thinblue
Thank you for the re-worked P422 review, the results are now very much as we would expect them to be. Great job ! There are many pitfalls that can occur and it takes a bit of time to learn the correct techniques to obtain accurate data and you have done well .
Just a few observations. I know you have mentioned this in your text, but it’s worth re-iterating that the results are fundamentally limited by the capabilities of your AP525 analyser. With its own measurement limit at 109dB SINAD it is really no better than the device under test (DUT), so we are as much measuring the performance of the AP525, as we are the P422. We really need a measurement system that is at least 12dB, and preferably 18dB better performing than the DUT to gain reasonably accurate results.
For information, as your main measurements were in dBV, below is a measurement of the P422 performance in dBr to be more consistent and comparable to the ASR measurements. It was taken from a unit going through production test this morning. It is a typical result. Please note that our production test measurement system also is not as good as the reference AP555 used by ASR. If the unit was measured on an AP555 it would be showing SINAD >107dB.
It achieves 106.9dB THD+N. Note that the result is extremely clean with no hint of mains spuria. Amp gain is 20.5dB suited for 4 volt XLR sources. Whilst it is not mentioned on our product page, the input buffer already has selectable 26.5dB and 20.5dB gain options. This can be operated via a jumper on the board. When we manufacture another batch of enclosures in the next few months this will be operated via an external switch on the rear panel. Note our gain settings will actually achieve full amp output by 2 and 4 volts RMS input – some other amps from elsewhere don’t cough….(hint – think about effect of gain on noise levels and final SINAD ).
As you noted in your review, our new (non Hypex) power supply is working very well, as demonstrated by the high 2 ohm output power. The PSU is very low noise, doesn’t suffer bus pumping and maintains output voltage even with high load and reduced mains voltage. This means, unlike other Hypex based units, it will achieve full power rating regardless of what the mains is doing.
Regarding Bruno Putzeys comments, yes he did say that our input buffer was more transparent than his Eval1 board. Purifi have had our products at their lab and used both our amps and speakers in their demo suite at the recent Munich High End show. We think this is a great tick of approval .
Claus Neesgaard – Purifi
Regarding the RF filtering, yes the Purifi Eval1 has bandwidth limiting, but not an actual RF filter at the XLR input pins.
We have implemented an RF filter right at the XLR pins plus appropriate bandwidth limiting in the buffer. This in itself is nothing new, just good design practice, however other manufacturers do not appear to be doing it. Some manufacturers even still use the Hypex eval board as a buffer which has zero input filtering, and its bandwidth is wide open. It’s a radio receiver!
Anyway, thanks again for your good work. I will talk to you about how you can cost effectively improve your measurement system beyond the capabilities of the AP525 in a cost effective way.
Cheers
Alan
thin bLue
thin bLue
Reviewer
I forgot to mention there was technical supports E1DA Discord Channel(@IVX, @staticV3 ). Now added!
thin bLue
thin bLue
Reviewer
Thanks @thin bLue
Is it possible to test the big boy - March Audio P501 1ET7040SA next?
I thought P501 is over kill, so I didn't think about that seriously.
But now, I think I should! I'll contact to Marchaudio.
thin bLue
thin bLue
Reviewer
Thanks. It would be interesting to see how it compares to the boxem 4222/E1, particularly in terms of output power since March Audio is using this Micro-Audio SMPS instead of the Hypex.
Please check this out!
