From 2pm today they started their anniversary sale. It may only be their Aliexpress store.Who's discount are you referring to; thanks?
The SA-1 was $
Don't mean to be dense, but could you post the link?From 2pm today they started their anniversary sale. It may only be their Aliexpress store.
The SA-1 was $480, from $599 usually. The Gustard H16 was around $350 and I was extremely tempted to go for it, but decided to stick with the SA-1.
YES send ass the link because i see different price range... in Europe the sa-1 is cheeper 499€
They're both singxers so it should work. Only a terrible/unsafe/failing/crap DAC will have non-negligible amounts of DC in its signal...I will receive my SA-1 tomorrow and was wondering if i can safely use the DC-jumper mod with my Singxer SDA-6 Pro?
The protection is there just in case though. I can't imagine it will sound different without DC blocking.
I think only an oscilloscope can see the difference haha.I will test it tomorrow. From what i have read it should Sound different but it also could be psychoaccoustic.
Since more people have been using this, how are you liking the single ended output / input? Is it a significan step backwards? I think the amp is designed with balanced in mind, so single ended might loose some quality?
If you had to choose between the A90 or the SA-1?
@SHENZHENAUDIO , any chance you've already sent one in for review per your post earlier in this thread?I wonder why this hasn't been reviewed by Amir yet. It's a really good amp.
OK so, far sounds amazing, but lacking in power, thought the Susvara would run good on this headphone, the A90 pushes it better as of right now.
I flipped the switches to the left, all of them to the left for gain, then I have it on Z-Low.
Does that sound correct?
