Monitor Audio Silver 100 Review (Speaker)
Rate this speaker:
    Votes: 15 5.6%
    Votes: 62 23.0%
    Votes: 159 59.1%
    Votes: 33 12.3%
thewas
That hump though... I wonder how much it impacts performance, especially for a tower. Would like to see directivity index though.
It is just an artefact from the non-correct addition of the nearfield bass measurements to the windowed measurement above at all Stereophile measurements, the Soundstage one is less flawed there:
Subway2400
Andrej
Again I agree, but the advanced and committed hobbyists here aren't "normal" in their relationships with their systems anyway.
Yes, and my point is that your choice is so much wider than when feeling obliged to cleave to the reflection dogma.
Only by those who haven't tried such spaces.
I can confirm from personal experience that sound absorption vastly improves stereo (and multichannel) playback. I have listened in my old listening room (20 x 28 x 10ft) while it was being constructed, from no absorption to most of the walls having 5 1/2in of rock wool and front half of the ceiling 11 inches of rock wool, all the way up to a large anechoic chamber, More absorption = better sound. Also, when available, better and better reconstruction of the recording venue ambiance. Of course, even that much absorption does not do much for very low frequencies, but every little bit helps:)
dgmen
I've always been a fan of the Bronzes and Silvers, although they've both creeped up in price over the years. I'd like to see both Stereophile and Soundstage review the new Silver 7G bookshelf models too. I find the new Bronze series to be disappointing, as they seem to be voiced more like B&Ws, with a rather V shaped sound, with recessed mids and a too hot tweeter, two attributes that I didn't experience from the older Bronzes, which, like these new Silvers, were well balanced. Apparently MA has seen how well this type of design does in the market place, judging by Klipsch's and B&W's popularity in the under $1000 market segment
Subway2400
The new Bronze series is not V shaped at all, it is pretty flat. Here is the Bronze 6G 100 :
It has nothing in common with Klipsch or B&W.
VintageFlanker
Paris
pathtonowhere
I had the Silver 100 6G for a while and I ended up selling it and buying the Diamond 230. The Silver sounded good on songs without bright highs. The bass was nice, the clarity was good, but on 20-30% of the tracks they became annoying because the highs were emphasized a lot and sounded like they were their separate thing that attracted attention and pierced the ears.
The Bronze is the same (despite somebody saying otherwise a few messages behind), the Silver 7G is almost the same. The waveguide of the 7G doesn't mitigate the problem well enough (maybe it's too shallow), and the 3-5kHz area has a very wide dispersion compared to the woofer. The 3kHz spike seems especially harsh, but in fact all high frequencies are too loud, the presence zone above 3kHz and the sibilance zone, too. Even with the dispersion problems, if the tweeter had been 2-3dB lower in output, maybe the speakers would have been usable on aggressively mixed tracks, too.
In comparison, the Wharfedale Diamond 230s sound more natural and are easy to listen to even on recordings with aggressive treble. You lose some detail on tracks that are perfectly balanced, but in exchange, you are able to listen to any music. And a lot of amazing music has aggressive treble, harsh mid-highs or sibilance.
VintageFlanker
Paris
All these are very specific... Do you have any measurements ?
pathtonowhere
I don't have measurements, I've listened to them and then returned them because they were too similar to the 6G version. In the 3-5kHz range, if you have no room treatment, you just end up listening more to the walls than to the speakers themselves. If you have treatment on the side walls/ceiling and a rug on the floor, they become listenable, although on some tracks they're still a bit too aggressive on treble. Despite what Subway2400 wrote, all Monitor Audios are aggressive on treble and somewhat V-shaped, with very few exceptions, Bronze BX2 (5G) being on of them. Even the Bronze 100 for which he posted the measurements are a bit too bright, you can see it if you compare it to other speaker measurements on that site, and especially on the 15+ degrees charts, where the 3kHz boost is obvious relative to the midrange.
So, at least for me, the Silver 100 7G which I tested would only work with about 3-4 square meters of absorbent treatment on each sidewall and on the ceiling, and with a rug on the floor, otherwise the room will ring too much on some tracks. The waveguie should have been a bit larger/deeper and maybe, at least for some listeners, the tweeter output 2-3dB lower.
PS: And, yes, relative to the B&W models with the 7kHz mega-peak, the MA models are less V-shaped. Any speakers are less V shaped than those B&W. I don't even count those as normal speakers, I just consider them defective junk, those were a April Fools Day joke, I have no idea who would listen to those, 10dB spike at 7kHz is unlistenable under any circumstance except being completely deaf
I have the MA Silver 7g and they do not sound shrill. They sounds awesome. What amp?
I have a similar experience here. I have the Silver 300 7G's and I find them well balanced, if anything, a touch warm sounding.
I know sometimes i think I am missing detail and run my jbl s38 in my other system to check and realize the detail is all there but it is not overpowering.
