Know example is another design but for Neurochrome HP-1 by
@tomchr, he told below about difference for 1/4 jack verse 5 pin XLR, note his HP-1 is also not a ballanced output but single ended:
QUOTE
That little bit of shared ground impedance in the 1/4" phone jack actually degrades the channel separation from 115 dB to 90ish dB. That's physics for you. There's no magic voodoo here. It's all Ohm's Law UNQUOTE
4-pin XLR. But yes. To further quote/paraphrase myself: I see no advantage of using balanced outputs. I think the fascination with "balanced" stems from the days of vacuum tubes where balanced circuitry was often used to get lower distortion. The issue with that is that the balanced circuitry will cancel the even order harmonics (those that most find to sound pleasant) while leaving the odd order harmonics (that many find to sound harsh) in the signal. But the overall THD is lower. This is what happen when you get tunnel vision and lock in on a single measurement as the holy grail.
There are cases where "balanced" matters. Balanced interconnects, for example. Or rather: DIFFERENTIAL inputs. Inputs that respond to the voltage difference between two signal conductors while being utterly indifferent to the ground potential. Such circuits, when used correctly, reject any signal that's imposed equally on the two signal conductors (mains hum for example). It wouldn't surprise me if many single-ended/unbalanced pieces of audio equipment operate with a level of mains hum that's just below audible. This creates various intermodulation products and results in a level of 'fuzziness' perceived in the audio. Switch to a differential setup and the 'fuzziness' goes away. I suppose I could write some marketing babble about "blacker blacks" or whatnot, but I'm not much of a wordsmith in that regard.
Some have extended this to, "well, if balanced/differential connections are good, then balanced/differential circuit must be even better, right?!" Well. No. Not necessarily. Differential circuits are used mainly for cancellation of some unwanted signal (such as mains hum). In the case of a differential receiver, the "cancellation factor" (common-mode rejection ratio) depends on the matching of four resistors. Given that ±0.1% tolerance resistors are commonly available ($1/each) and ±0.01% tolerance resistors are no longer carved from a solid block of unobtanium by certified organic virgins ($10/each - for the resistors, not the virgins!) getting good CMRR is quite achievable even at the PCB level.
However, if you are trying to cancel distortion in a circuit by using a balanced design, you're in for a rough go - especially in a discrete circuit where the matching between active components tends to be rather horrid. Thus, if you rely on transistor matching in a discrete circuit to cancel any unwanted signal, you are much more likely to degrade performance than to improve it in a balanced design.
In IC design, the situation is different. The matching between components on an IC (at least assuming the process has been optimized for analog circuits), the matching between components is much, much tighter. The absolute tolerances on components is worse, but the matching is much better than at the PCB level. Thus, IC design tends to derive its performance from the matching between components, which tends to result in differential/balanced designs.
Some fret about balanced connections from the input to the output of a box. I'm not one of them. As I showed in my HP-1, it is perfectly possible to get stellar performance with single-ended signalling within the enclosure. You just have to pay attention to the PCB layout.
Now, in my upcoming HPA-1 (under the
Tom Christiansen Audio brand), I use differential signalling all the way to the volume pot. Why? Cuz I can... It doesn't cost me any extra to put the differential receiver by the volume pot and it gives me a marketing blurb, "balanced all the way to the volume control!" Will it make any difference in the performance? It might, but most likely it won't. And most importantly: It will not degrade performance.
NB: Observant readers will note that I'm using the terms differential, balanced, and balanced/differential interchangeably above. I'm well aware that not all balanced circuits are differential and that not all differential circuits are balanced. I assume that the reader is savvy enough to infer that I'm referring to well-engineered implementations of differential circuits (which are also balanced) and not some hack.
BTW: Those interested in learning more about component matching (and layout matching) should take a look at
Marcel Pelgrom's work.
And in the manual
"The right-hand jack is a 4-pin XLR headphone jack that features dedicated returns for each channel.
The main purpose of the second connector is to provide a high-performance alternative to the traditional TRS phone jack."
It's impossible to have perfectly same balanced out and single end out if the using the same circuit. The noise has to be doubled, output impedance has to double, output voltage swing(power for high impedance)will be doubled(quadrupled).
Correct. The only advantage of the 4-pin XLR is that you skip the few mΩ of shared ground in the 1/4" phono connector. You better hope that the layout designer of the headphone amp use a ground plane as using a ground trace would degrade performance even more.
Also correct that you cannot use the same output for balanced and single-ended. That would short the two (-) outputs of the balanced driver together and now you're back to single-ended.
I would further argue that using a second (inverting) driver to form a balanced (but not differential) output just so you can claim to have "balanced out" on the XLR (and get to claim higher output power) is 99% marketing, 1% stupidity, and 0% engineering. Twice the noise (= 4x the noise power!), twice the output impedance, likely higher distortion (due to poor matching between the two amp halves), twice the cost. Yeah. Not my cup of tea. But you get more output power...
Tom
