Review and Measurements of SMSL VMV D1 DAC
maverickronin
Midwest, USA
It would be dissipated in the tweeter coil, but as its level is at -110dB or below this is not the issue.
Hopefully it isn't. Amir didn't measure it out to 1.8MHz.
The SMSL most likely won't have anything at high enough level to present a safety hazard to the tweeters, but something that's defective, damaged, or poorly designed enough just might. My point is that it's better for an audio amplifier to be band limited to something resembling the range of human hearing rather than attempting to cross over into the ham radio market in for the sake of putting bigger numbers on your spec sheet.
yummy
looks like the problem was that indeed fully awt from head to toe makes some gear look "normal" but with uwt the true monster is out there, the board needs to redone
gvl
SoCal
I'm sure awt will make filterless NOS look quite nice too.
CaptObvious
Sorry newbie here, AWT/UWT means?
derp1n
Any other correspondence from SMSL? Its been quiet here for the last couple days.
They were closed on the weekend. Came back on Monday and said it would be a bit before they would reply.
They had me try something which unfortunately did not fix the problem.
gvl
SoCal
CaptObvious
Looks like SMSL added your review @amirm to their Facebook page
maxxevv
If balanced output ( which a lot of "audiophiles" obstinately insist on) is the measure, Amir's review and measurement of the V1 is really quite the endorsement.
Such independent, unsolicited measurements that reflect so well on the parameters that matter for their target customer base are priceless for them imo. You hear it so often over at headfi and a few other forums "I only care about the balanced output ... " * rolls eyes * ....
CaptObvious
Still, if you offer the option of both unbalanced and balanced, both should be somewhat comparable. Especially at the level/price they are marketing at.
Though now I'm curious, looks like they are releasing a SMSL VMV P1 headphone dac/amp based on the D1. Maybe it will correct the issues in the unbalanced side of the D1?
gvl
SoCal
Just use one leg of balanced on D1 for your single-ended needs, it is clean.
derp1n
Or they could engineer it well enough that such workarounds aren't needed.
Roen
Time to wait for the "D2" if they release such a DAC.
