Review and Measurements of Topping D10 DAC
To update my last findings. Apparently I can only reproduce this if I turn off the AMP while playing. If I stop the music before and then power cycle the amp nothing seems to happen. While this is a workaround for me, I still want to understanda how the DAC can be affected by power cycling a connected AMP.
This is really strange. I wonder if the amp is backfeeding into the RCA jacks on power off. Which amp is it?
Krunok
Zg, Cro
It seems that power-off transient somehow manages to find it's way via the RCA jacks to the DAC and disrupts it while its doing the conversion..
True but why would an amp send transients through its input connection. Output, I could understand. But input???
Those transients can damage audio gear as they do not expect their output to be driven by anything.
I like to duplicate that problem. Is the AMP reasonably priced so that I can purchase it?
It is not the off but the on. Is it possible that the moment you turn it on it gets an initial higher current because the internal power supply is not fully up yet so it tries to get it via the RCA. The d10 detects it and goes in protection mode killing the output. This might explain why it is not happening when no audio is playing since then the relay is closed.
RayDunzl
Central Scrutinizer
Riverview FL
I have the output of the D10 connected to my Headphone amp. If I turn the headphone amp OFF during play and then back on (sometimes I need to do this several times), my D10 crashes. What I mean with crash it that the display resets shortly back to 44.1kHz and then the ouput is muted. If I then switch to a DSD file transferred via DoP it still shows me PCM albeit with a higher kHz value.
What is the power source for the DAC, and for the amp?
Krunok
Zg, Cro
In any case, as a general rule I would never recommend turning the amp off while music is playing - that is something your headphones wouldn't like as well.
I normally also don't do that. But I was recabeling and turned it off minimizing the volume first and when turned it back on I noticed the issue. Then I tried reproducing it without connected headphones
Sami
Finland
Can you try (powered down and all power/rca/usb cables disconnected):
1) continuity (using multimeter) in the amp: between rca input ground and iec socket ground, and between rca input ground and case
2) continuity in d10: between line out ground and usb ground, and between line out ground and case (for example the screw at back panel)
Also, is amp properly grounded, that is, iec ground pin goes to mains earth via a proper cable?
Also, what device is connected to d10's usb, and how's the grounding in it?
