Sabaj D5 - Owners' Thread
Mr. Olinad
Guarulhos - SP
Does any of you have had access to this tool?
My D5 is v1.2 and I don't like the idea of being stuck forever in this version.
I'm trying my best to find this tool or some alternative.
The cable was easy: 10 Pin FPC FFC Flexible Flat Ribbon Cable
About the "tool", after some research I think that words like "STM32" "SWD" and "JTAG" are the ones I'm looking for, right?
So I found this one:
Would it work?
If so, what kind of adapter should I use to connect this J-Link tool to the Flat Ribbon Cable?
This one?
In the end, even if these pieces are all I need to do the job, I think the biggest challenge is to know if I should connect the ribbon facing up or down. :facepalm:
AnalogDE
California
Would it work?
This one?
You sure want to use this device and possibly brick your D5 ?
RickSanchez
Cartographer
Austin, TX
And following up on that point @Mr. Olinad : I assume all you want to do is upgrade the firmware to v1.4? If so, have you been able to contact Sabaj support? They should be able to send you the upgrade tool. I've read a number of threads on ASR where D5 owners -- ones who purchased the device months ago, when it shipped with v1.2 -- got the upgrade tool directly from Sabaj support. That seems like a much easier/safer path to the firmware upgrade.
Mr. Olinad
Guarulhos - SP
No... not without instructions of someone that really knows what to do.
As this hobby is full of experts I thought that maybe someone could help in case Sabaj simply stop shipping the tool.
Yeah... I've been looking for a firmware update for a while so yesterday I ended up in this thread.
I wasn't following the measurements thread where it was previously discussed and, as I read some posts of people mentioning they haven't had access to the Tool, I just started my research.
I sent a message to Sabaj Official Store chat on Aliexpress, from where I bought it, and they haven't answered yet.
If any of you know a better channel where I can contact them, I'll be glad.
Tks
Harry1973
Finland
^ I contacted them via amazon (bought it there). I got reply on the same day (instructions and address where to upload the file). They also sent me tracking info of the tool itself (however it did not work) but tool arrived couple of weeks later. Mine was 1.3 originally. Now 1.4. -I have using Sajab D5 for couple of months daily (6h /day). No issues. Still love it.
Tom C
Wisconsin, USA
Can anyone please tell me how to install the driver files? I’ve downloaded the driver from the Sabaj’s website. The file has a .rar extension. It appears to be a zipped file, but I haven’t been able to unzip it, or to get Windows 10 to recognize it as a driver for the Sabaj.
Harry1973
Finland
When I downloaded the zip file, it was .7z -file. In order to open this type of zip file you need .7z extension or programme. Google "open 7z. file".
Once you have opened up the zip file, you will notice that it contains the files mentioned on the pdf.
EDIT: Sorry, I noticed you were talking about the driver file (I was talking about firmware update file). Cant help you with driver. I use the dac with streamer.
Mr. Olinad
Guarulhos - SP
No matter if its .zip, .rar, .7z or whatever, 7zip usually does de job
https://www.7-zip.org/download.html
It's free, just choose according to your OS.
Mr. Olinad
Guarulhos - SP
I contacted via Aliexpress (bought it there), here's what they said:
I'm still waiting for the email.
RickSanchez
Cartographer
Austin, TX
renaudrenaud
Tianjin
Received a Sabaj D5 yesterday. At first I thought it was not working. Sound was awful with XLR line output. Then, trying the menus, I found the headphones output was selected. After the selection of the line output, it was ok. So, with this version of firmware, it seems not possible to have line out and headphones selected in the same time. Could you confirm it is the same for you?
Mr. Olinad
Guarulhos - SP
I think it's the same on every firmware version.
You have to choose one of them only.
v1.2 here btw
renaudrenaud
Tianjin
Not a lot of life in this thread so I decided to put a picture.
I had a complete week without appreciating the Sabaj D5 because there was a problem on my amp (my fault). The problem was not obvious and at first I thought the Sabaj "not so good". The headphones output was ok so I tested then from XLR to RCA and it was working correctly. I discovered the real Sabaj D5 but was not where was the problem.
Today I was able to fix my error and then it is now working fine with XLR cables between Sabaj and amp. I am not able to hear any difference between RCA and XLR anyway, but I use the RCA to move vumeters in the K7 player (waiting for a project with an Arduino and big count of LEDs, maybe in January).
I am also very happy with the headphones output and the easy to drive AKG Q701.
qxp
Does anyone have a unit with a solid volume knob? Mine just arrived and it rattles around side to side. The center button is equally loose.
I'm on firmware v1.4, and I noticed that there's acceleration (skips steps) when I quickly turn the knob counterclockwise, and no acceleration clockwise. I don't think this is intentional, and the processor may be missing the fast encoder pulses.
Mr. Olinad
Guarulhos - SP
I see no problems on mine.
Yes, there's acceleration counterclockwise and no aceleration clockwise.
I think the acceleration is needed due to situations like when you are surprised with a high volume and needs to turn it down asap to save your headphones or speakers.
AnalogDE
California
The first unit I got has a rattle-y volume knob. I ordered a second unit about a month back that feels more solid.
qxp
Thanks. I'm in touch with Polly from Hifi Express and she says it's normal for the volume knob to wiggle.
It's disappointing that the volume knob is flimsy on an otherwise solid DAC.
I'll see if I can get a replacement.
Paper Tiger
I just recently acquired a Sabaj D5 and I was wondering if anyone knows a way to turn off the OLED display?
