SMSL DO100 Review (Stereo DAC)
Rate this DAC:
    Votes: 4 1.1%
    Votes: 7 1.9%
  • 3. Fine (happy panther
    Votes: 33 9.2%
    Votes: 315 87.7%
This is a review and detailed measurements of the SMSL DO100 stereo balanced DAC with Bluetooth. It was sent to me by Aoshida Audio and costs US 239.
Sorry about the fuzzy front panel picture. It looks better in person. The rotary control makes it nice to adjust volume. Back panel is the usual affair but with USB-C connector instead of the usual Type B:
Nice that AC adapter is built into the unit so you don't have to worry about a dongle. The usual SMSL remote control is provided.
SMSL DO100 Measurements
Let's start with our usual dashboard using XLR balanced out:
This is superb performance especially at this price, landing the DO100 nicely in our top 20 list of best DACs ever measured:
RCA output is just slightly worse:
Same shows up in dynamic range:
Multitone test shows the extremely low distortion:
We are talking 15 dB lower than threshold of hearing folks!
IMD distortion is excellent with ever so slight hint of "ESS IMD Hump:"
Jitter performance is superb across all three inputs -- something we don't always see:
Linearity is textbook perfect of course:
Seven different filters are provided:
Using the default filter 1, we get incredibly good performance in our wideband distortion measurement:
SMSL DO100 DAC Measurements Stereo Distortion vs frequency XLR Balanced USB DAC.png
This is a flawless performance from SMSL. Every test is aced, leaving no room for any complaint whatsoever. When you consider that this state of the art performance is offered at relatively low cost, it is quite an achievement. There is no excuse left to not opt for full transparency folks.
It is my pleasure to recommend the SMSL DO100.
F1308
Congratulations, SMSL.
Just a tiny bit short of perfection.
Add lossless Bluetooth and allow control via an Android APP, removing the price dedicated to the already included remote, and it will be there.
Grotti
What an impressive little unit! And thank you @amirm for being so busy....
At this price point I am on the fence to buy one just out of curiosity. At least in terms of electronics we seem to live in a golden age.
VintageFlanker
Paris
Exceptional performance at this price point.:cool:
At least a cheaper alternative (Balanced DAC with physical volume knob and integrated PSU) to the SU-9. This should do a great job when paired with power amps, such as assembled Ncore etc.
Add lossless Bluetooth and it will be there.
Supports both LDAC and Aptx-HD. Should be enough for BT usage...;)
Robbo99999
Very nice! A balanced DAC with remote control and all manner of input options, and perfect measurements whilst not being silly expensive - about the best DAC you could hope to have for 2 channel output. I'd probably get this DAC if I needed balanced outs, but I managed to fix all ground loops so don't really need that, but the extra power associated with balanced out could be useful for some people driving hard to drive headphones (not many of those about though) and of course for solving ground loop problems. Best value / best performance balanced DAC we've seen so far?
Astojab
That looks great and is even a bit cheaper than the E50 I am currently using in my livingroom set up. Does anyone know whether the SMSL remotes are better than the Topping ones, cause the E50 Remote is annoying me (you have to be very precise in pointing the remote towards the DAC).
Bleib
Sweden
Red_Red
Europe
A priori a very good little Dac indeed, but apart from the Jitter I unfortunately do not see any measurement with the coaxial input...
Can you make them or if it is done put them online? For some of us this is very important!
In any case, thank you, once again Amir, for this test.
Red_Red
Europe
Jitter is usually the only measurement where you can see a difference between USB, Spdif, and Toslink with these DACs.
So not always... ;)
And if so, we would just appreciate if Amir clarified it with a sentence like "the measures are equivalent whit the other inputs"
TabCam
Very good measurements is not the only factor for solid engineering IMHO. How does the device react to turning on/off, switches to different types of input 44.1 -> 48 kHz, 16 -> 24, DSD, PCM etc. without any pops are also signs of good engineering. It is even more important with streaming audio as big as it is nowadays, either from an ISP or locally.
Bleib
Sweden
And maybe this too?
Any high pitched noise (coil whine) coming from DO100?
audible at 5-10 cm from unit.
Taken from other topic
AudioSceptic
Northampton, UK
Great results. Why doesn't every product using ESS chips allow the user to choose from the range of filters like this one does?
