Topping D30Pro Review (Balanced DAC)
Jimster480
Tampa Bay
Just got another A30Pro/D30Pro stack together today. Forgot how nice it is to have a DAC with no MQA or bluetooth antenna I never use. I think they really got it right with the D30Pro, 3 prong grounded power cord that's easy to replace. Been using an A90/E50 stack and the A90 does sound nicer, but if you can't find a D30Pro, the E50 with a Samsung ETA0U60JBE charger does just as well. Just have to relocate the serial number sticker to the bottom and clear tape over it.
I've never considered it to be "nice" to not have features on products like this even though I don't use them... That is quite a weird metric... But to each their own.
aka_Z
Santa Clara, CA
I guess, it has a better sound without MQA (even if it's off) and BT antenna. Especially antenna, it can affect audio waves a lot! :D
Lupin
Topping had every intention to release the D30 Pro with bluetooth. You can see this on the display where there is a bluetooth indicator cutout right next to the USB indicator, also the contactpoints for the bluetooth module are there on the PCB. But then covid happend with the well-known shortages and Topping decided to push out the D30 Pro anyway but without bluetooth.
domiji
Hello ASR-Community,
i love my D30 Pro but i am a bit confused about the "filter" discussion. Which filter is recommend for the best "theoretical performance"?
Thank you all for your help and have a great day
Dominik
Human Bass
Whatever filter cuts stuff ultrasonic the hardest, in this case F2
Dominik
Gremlins
Dominik
Why bother, impossible to hear difference
And why ask others about a select you can do on your own in your living room
Your choice is the best you can do
Lupin
Played with the filter settings when I just got it out of the box. Couldn't hear any difference whatsoever with any setting so put it back to default F2 and never looked at it again.
Actually I have not touched the DAC in forever since the DAC automatically turns on and off :)
razamanaz
The driver 5,62 does not allow installing ASIO for foobar
"Could not load component "foo_input_sacd.fb2k-component": This component was built for a different processor architecture."
staticV3
Not a driver issue.
You're trying to install a 32bit plug-in onto a 64bit version of foobar.
Ahmonge
Valencia, Spain
