Sokel
- Joined
- Sep 8, 2021
- Messages
- 6,226
- Likes
- 6,352
So,what it really says on the manual is that it does digital attenuation on the analog outputs(don't they all?).That's a nice clarification.Okto uses digital volume control. Ultralite Mk5 uses digital volume control. Topping DM7 uses digital volume control. And so on.
Running a DAC with no attenuation and using a downstream analog volume control potentially has a noise benefit over digital volume control (whether in DSP or DAC) as it will attenuate noise from the DAC at lower volume levels. However in practice such multichannel volume controls often have channel imbalance issues and typically have worse noise performance than the DAC alone, see the Volume8 as an example -> https://www.audiosciencereview.com/forum/index.php?threads/spl-volume8-review.34870/.
A big benefit of these high dynamic range DACs is you can use digital volume control and not have any noise issues.
Michael
Thanks!
