Did anyone compute an “Olive Score” for these?
And dirty at that
The tweeters are aimed at the eyes, but the MRZ is at the toupee’s.Anyone have a thought on why the midrange would be angled upward some 30 degrees while the tweeter and woofer face flat? I get the stepping for time alignment, but how could angling the midrange differently help time align?
The link provided gave a preference score of 4.4 and 6.2 with a subwoofer. Better than I would have expected really.And dirty at that
Seriously - I am having a hard time finding the method to get to a score.
Does anyone know what magic words result in some link that explains it?
A large part off axis is the 1st order crossovers. Going with steep crossovers will help, how much is hard to say.
1st order crossovers by their nature always cause large off-axis lobes if the on axis is anything close to flat. Those off axis lobes will lower the score on the preference rating. Using steep crossovers will eliminate or minimize that which should raise the score and improve the sound of the speaker in room. Now how well that works when the speaker was put together for 1st order crossovers I don't know, but it still should be a step in the right direction. Look at 10:59 in the video. The response off axis is all over the place.Would it help?
It seems like the horizontal spread is not bad, so maybe I don’t understand?
Just knocking down the on-axis peaks is usually worthwhile effort. As discussed, you can get crazy with higher-order crossovers, but then why start with this vintage speaker?
I have the 1B till now it creates the best imaging i ever heard. When using room correction they sound even more balanced. People that hear them are impressed.I have owned them for 38 years, and most people that hear them say, “WTF@ How can they sound so good.“
I am also emotionally attached to them, with load of history… if they could talk.
For a 40 year old design they are not bad.
Yeah - it’s hard to make a speaker time and phase if the passive crossover does not allow it.
Maybe one can get a way there with Dirac?
And it is easy to straighten out the FR with some EQ.
I forgot what you are running the 1B with?
I have the Lyngdorf AVR/AVP for HT, but I am almost considering their TDAI 1120 or 3400.
