- Joined
- Feb 23, 2016
- Messages
- 20,822
- Likes
- 37,746
A missed opportunity for innovation. The portless port design.Sorry cut and paste from another speaker. It has no port.
I googled for pics of the speaker although the model has limited pics on the net. I assumed that maybe the port is on the bottom.A missed opportunity for innovation. The portless port design.
mal conceptionI think this is Vandergek or of the mad
I saw a video on that recently. And, well, yeah - designs like this are almost always an unmitigated disaster.The simple fact of the woofer being “on” the baffle instead of flush is an almost immediate sign that the response will be jagged. Even moreso with the frame being cut to fit on the sides
Me either... it's literally like they've just thrown a driver in a cabinet and thought yeah that looks fine, start making and selling them. The design part is completely missing... let alone any measurements. 101 - how to design an expensive and horrible speaker.Jeebus! Was not expecting this from such a storied manufacturer as Vandersteen.
They make the same speaker with a carbon tweeter from their System 9 speaker ($150k plus) for $3291. Probably just needed a better tweeter.
Yes was sarcasm.I don't know if this is sarcasm,........snip.
Duntech Sovereign had first order crossovers, I thought they sounded great. I wonder how they measure, but not holding my breath to find out!Yes, some of these old school speaker companies could upgrade their designs by using REW and a Umik-1. The upgrade could be considerable. Not to mention if they then did outdoor ground plane measuring to get closer to accurate results.
Have you yet measured any speakers with 1st order crossovers that do well at all? I cannot think of any.
And one can extend bass a bit with this setup if the box is too small. I’ve used this setup once in a small closed sub. Works well: https://www.lautsprechershop.de/hifi/aka_tief_c.htmThe impedance sweep suggests there is a series capacitor (high value) in series with the woofer, probably deliberately to prevent LF getting to the driver.
That innovation has already been done, it’s called a passive radiatorA missed opportunity for innovation. The portless port design.
Thanks Amir for the test, measurement I just started by saying.The simple fact of the woofer being “on” the baffle instead of flush is an almost immediate sign that the response will be jagged. Even moreso with the frame being cut to fit on the sides
Yikes! I'm surprised the panther's head is still nearby the body!I rank the Vandersteen the second most broken speaker I have ever listened to or measured.
