Hello everyone !
I am looking for a new set of speakers to buy but completely do not have an idea which one should I look for. No idea because for my last couple of years I was using open baffle speakers only (Audio Nirvana 15 Super Alnico, Lii Audio F-15 - these are very sensitive around 97db) and I was sure that open baffle sound is better than conventional boxed speaker sound. Now I have done some research on audiosciencereview forum and it looks like going back to conventional boxed speakers is the way to go when it comes to sound quality.
My actual system is:
Minidsp SHD — 2 x Audiophonics Purifi mono blocks — 2 x Lii F-15 + 2 x Rythmik F18
and of course I am using Dirac.
I would like to get rid of open baffle speakers which means that F-15 speakers are the ones which I would like to change for a conventional boxed speakers.
Do you have any idea of which speakers I should look into ? I am looking for the speakers which obviously are the best when it comes to performance/price ratio but if there is anything pricier but worth it then maybe I would up my budget.
I like my music to be very loud sometimes and I do not like my system to have any limits especially in spl.
In the future I will change my Purifi for 2 x Benchmark AHB2 to have around 400 Watts per channel but “only” if it will be necessary and only if the speakers which I will buy will need that and will give me any benefits with such an extra power.
Guys, one more question which I have also is about extra 2 x Rythmik subwoofers as my future plan is to buy another two and have four of them in total for stereo music. Is there any way I could use 4 x Rythmik subs in my system with Minidsp SHD ? If yes, how I can integrate it ?
I know SHD have four outputs where 3 and 4 are for subs optionally, so is there any option to integrate four of them or not at all with SHD ?
Best Regards,
Raf
Best Regards,
Raf
