Why are most bookshelf speakers made for analog?
DaveDee
Most people aren't listening to music on record players or CD players anymore. They listen to digital playlists, whether through smartphone or computer.
I got the Neumi BS5P recently and it comes with a RCA to RCA cable instead of a RCA to 3.5mm cable. Why? The latter should be the norm.
kongwee
Because bookshelf only accept audio analog. Also people enjoying listen on sofa.
Duckeenie
The majority of the smartphone market doesn't want to plug their phone into a pair of speakers, they're happy using bluetooth.
JiiPee
I'd say that there are two separate categories:
a) Bookshelf speakers that are intended to be on bookshelves or speaker stands, and connected to audio electronics via speaker cables if passive, or via rca/XLR/spdiff/toslink/usb/wireless if active.
b) Desktop speakers that are intended to be connected to computers/PDAs/smartphones via various means typical to those equipment.
The use cases are different.
JiiPee
Even though majority of us may listen music from computers (whether from a local computer, or via network), it does not necessarily mean that we want to connect our speakers directly to that computer (or to some connected wireless device). Many of use separate DACs and separate amplifiers anyway.
AudiOhm
London, Ontario, Canada
Actually I am surprised that any Audio equipment comes with cables any more.
I have so many, I wish they would stop.
Ohms
D
DaveDee
Has anyone ever measured bluetooth? I assume it's terrible.
D
DaveDee
Is there a real benefit to using, say, a Topping D10s with active speakers? Just louder volume? I was considering getting one but my speakers are already powered so I don't know if the difference would be significant.
Moderate Dionysianism
No it isn't. The LDAC codec performs really well:
JiiPee
Ohms
Maybe in the future we have wireless connections and battery powered equipment with a separate charging station? Of course this is already what we have with PDAs/smartphones.
Talisman
Milano Italy
you're assuming wrong, you probably wouldn't be able to hear the difference even at low average bitrates, And in any case it's possible that some smartphone dac implementations are an even worse evil
Hexspa
Old Bluetooth had more limitations. Afaik Apple is not supporting the most recent version. I could be wrong.
Hexspa
Is it not so that even the most basic Bluetooth supports almost 300kbps? The question is whether all that data is for audio and I believe it’s not. Using a regular mp3 as a standard, I think most people can distinguish between 128kbps lossy and lossless, even if it takes some training. By 256kbps, I’m not sure and I consider 320kbps to functionally identical to lossless assuming you’re just listening and not heavily processing the file.
D
DaveDee
I believe anything wired always performs better than wireless, even if inappreciable.
Sal1950
The Chicago Crusher
Central Fl
Better ? More reliably, possible.
I'm old school and with you on this DaveDee
I use wired network where ever possible, etc.
Aerith Gainsborough
I used to believe it too when it came to gaming mice.
Until I got my G700s a few years back.
Never looked at cable mice again. Not having a cable work against you is so much nicer.
In audio: BT isn't lossless, maybe perceptually transparent but still not lossless. Still, convenience beats the potential loss in quality by a landslide.
Transmission via wireless home network is literally bit-perfect.
D
DaveDee
Many people like to spice up their hobbies with beliefs. Nothing wrong with that, of course. Bit strange in my opinion, but different strokes for different folks.
That's what I meant by better, as in more reliable.
TonyJZX
i think OP is skipping a few steps
there's active speakers
there's active speakers w/ bluetooth
there's passive speakers
pick your poison... capitalism means there's heaps of choice in these categories
