WiiM Mini Streamer
id.ray
Thank you ralph, also found this on that page... looking forward to this.. might have to sell the blusound and get one of these and hook it up to a topping e50 which will render mqa through toslink
Tidal Connect - will this pass through hifi quality or even master quality to an external dac to unfold? Does this support an external dac through tos? Print
Modified on: Wed, Mar 2, 2022 at 11:39 AM
It passes through HiFi quality (not Master MQA) to the external DAC via TOSLINK. We have a plan to support MQA later this year.
Ralph_Cramden
High hopes for the WiiM, but fingers crossed. It's using a newer version of the LinkPlay modules in devices that @amirm has tested in the past. They all measured pretty poorly. Let's hope this one measures better.
Jmudrick
Bubble Upnp rolled out a new Audio Cast feature today in Android. Selecting Audio Cast and the WiiM as renderer not only allows Apple Music playback (Apple Music doesn't see the WiiM), but it does so gapless. Control is via the Apple Music app. This is pretty great. Is it lossless? AFAIK, Bubble Upnp reports "WAV 44.1" but can't be sure.
TimW
Seattle, WA
Hmm seems convoluted.
Also it seems like you can only use it for 15 min if you don't have premium?
Jmudrick
Sure, having to use two apps rather than one is an inconvenience but it works as when Apple rolls out its classical interface it may render Qobuz a second place choice for me . Bubble Upnp and USB Audio Player Pro are both worth the pittance required to support their work as far as I'm concerned.
TimW
Seattle, WA
You're right, I hadn't thought about the fact I was using the free version but I have really liked it. Just paid the $5.
Jmudrick
Bubble Upnp Audio Cast also supports the XM Radio.app which is handy if you use it. The app otherwise doesn't recognize the WiiM device.
flz
Sorry for my ignorance but what exactly is the function of these LinkPlay modules? In at least 1 of these 3 reviews you cite, Amir used both an ethernet connection in and an optical connection out to external DAC. In that case, the limiting factor should not be either Wifi, bluetooth, or the internal DAC since none of those were used.
Someone recently wrote in this thread that all streamers should perform exactly the same when using the optical out to an external DAC. That doesn't seem to be the case.
flz
Yes, I do. You will find quite a number of measurements on this site supporting my opinion.
So Amir tested 3 streamers (all using LinkPlay modules) that all tested horribly even when using optical out to external DACs. If you're saying all streamers perform the same when using optical out to external DAC, then ALL streamers are that bad? See link below (Post #42 of this thread).
Ralph_Cramden
Sorry for my ignorance but what exactly is the function of these LinkPlay modules? Someone recently wrote in another thread that all streamers should perform exactly the same when using the optical out to an external DAC. That doesn't seem to be the case.
If the streamer's digital output is bit-perfect, that's true. If it's poorly engineered, such as truncating 24-bit to 16-bit, and introducing so much noise that it can't output bit-perfect even at 16 bits, then it won't perform the same via an external DAC, as @amirm has measured.
Linkplay does all the heavy-duty engineering that, for example, Sonos does, including cloud services connecting to all the various streaming providers, licensing deals with the providers, highly integrated hardware, etc. It provides all this to third-party audio companies that don't have the technical resources or expertise to do it in-house. In the case if the WiiM Mini, LinkPlay appears to be selling directly to consumers vs through OEMs.
mugbot
Adelaide
I wish it did chromecast :(
ClassicGuy
If I connect a Bluetooth remote to the Android phone/tablet that has LinkPlay app, can I control Wiim Mini using that remote? Such as play/pause/prev track/next track? Also mute/vol+/vol- ?
flz
Many of us are waiting for Amir's review of this device. Before that comes out, has anyone looked at the published specs (linked below)? Specs are given for "Line in to SPDIF out" and "BT in to SPDIF out". For example, for the BT in to SPDIF out, they say SNR = 297 dB and dynamic range = 213 dB (which are much better than for Line in to SPDIF out). But they didn't say anything about Wifi in to SPDIF out. Can anyone draw any assumptions/guesses about performance from any of this?
Specs - WiiM Mini - WiiM (wiimhome.com)
MaxBuck
SoCal, Baby!
Hi,
I was thinking about adding node 2i to my system as digital transport to my dac. But with wiim mini i can have exactly the same for 1/5 price of node. It will be any sound difference When using optical out only? I know about difference in clocks, but really it will be any notacible difference? @amirm we are waiting for your test and advice! Thanks
The difference won't be in sound quality. It will be in availability of streaming services and the convenience and usability of the control application.
flz
Some of you insist that streamers wont have a sound difference when using the optical out to an external DAC. But look at post #42 of this thread. Amir's tests clearly show differences in streamers even when using optical out to external DACs, with some streamers performing very poorly.
MaxBuck
SoCal, Baby!
I said the WiiM and the Node wouldn't sound different. I haven't studied the others.
Reactions: flz
thorvat
That happened because of poor implementation of digital volume control which affected performance over SPDIF. It is something that you don't see often, but it is of course possible.
Btw, we live in a days when it is very easy and cheap to build your own streamer that will perform exceptionally. Get yourself RPi4 and ToppingD10S, connect them via USB, install streaming software of your choice on RPI4 and you've got yourself a perfect streamer. You can even add room EQ software on it.
Do we know when @amirm will do the test of this streamer?
I am still working through stuff that has come earlier. Let me see if I can get it done in a week to 10 days.
