Ralph_Cramden
- Joined
- Dec 6, 2020
- Messages
- 2,616
- Likes
- 3,546
WiiM Remote is finally listed on Amazon, though not yet available.
No less than 96/24 to get a max from Tidal.What bit rate option should I choose during setup of wiim mini when using spdif with Tidal or deezer 16 bit 44.1 or 24 bit 192
Did you select hi-res option in the Qobuz section of WiiM app?I've signed up fpr a trial with Qobuz and the highest sample rate I seem to get from the WiiM App is 44.1 ... is that right, I though they went up to 192?
Have you configured in Wiim Home, the sampling rate has 192 of the toslink output?I've signed up fpr a trial with Qobuz and the highest sample rate I seem to get from the WiiM App is 44.1 ... is that right, I though they went up to 192?
With the WiiM Pro, you can use Chromecast to cast from the Qobuz app up to 24/96 (the Qobuz app deliberately caps Chromecast at that)Think I may get frustrated with Qobuz though as you can't cast from it's App and have to use the WiiM one.
Yeah, that and the availability of bit perfect Amazon Music support (including casting) till WiiM came along. I have Linn gear and the preference from my dealer has been Qobuz and Roon with scant regard for anything else…I keep seeing posts saying Amazon HD doesn't sound great, I'm not sure if that's people just a bit anti the Amazon giant or bias from Audiophiles who have maybe have seen Tidal / Qobuz as more serious for the HiFi enthusiast over the years so therefore consider Amazon as inferior.
You can use Stream What You Hear to present your pc audio as a webstream, and use the Open Network Stream feature in the WiiM app to play that stream. The more recent version of SWYH can also direct the audio to a UPNP renderer like the Wiim devices.I have a problem with wiim mini.
It turns out that wiim home app can send streaming services (some at least) to wiim mini.
But I can not make any browser accessed streaming audio to be routed to it.
I also have room correction setup with my Jriver. Although Jriver can easily play to wiim mini, playing local files, but streaming from internet is out of question.
Anybody knows how it can be done?
I don't think you can do it with the Deezer app, but with Tidal Connect no problem.Does anyone know how easy it is to cast Tidal and Deezer to the WiiM's and can you do it from their native Apps?
There is a feature in Deezer that purports to be a Connect mechanism but I understand it’s more a remote control for another Deezer app running elsewhere, and as the WiiM devices don’t run the Deezer app it’s of no use to WiiM users.I don't think you can do it with the Deezer app, but with Tidal Connect no problem.
I replied to this on Wiim forum, here is a copy.You can use Stream What You Hear to present your pc audio as a webstream, and use the Open Network Stream feature in the WiiM app to play that stream. The more recent version of SWYH can also direct the audio to a UPNP renderer like the Wiim devices.
GitHub - dheijl/swyh-rs: Stream What You Hear written in rust, inspired by SWYH.
Stream What You Hear written in rust, inspired by SWYH. - dheijl/swyh-rsgithub.com
