My Asus RT-AC86U is now considered old too but fortunately has some good features.Very few routers support DoT at that time. Mine does not, even though it is a 3 years old model, still supported with firmware updates.
yes, it has an analog line output.Hello everyone, could you tell me if this unit transmits Tidal HiFi plus by connecting it directly to the amplifier or do you need an external dac?
Thank you
Mine doesn’t have that setting either (Netgear r8000)Very few routers support DoT at that time. Mine does not, even though it is a 3 years old model, still supported with firmware updates.
Thanks, I cast Tidal wifi plus to Chromecast Audio connected to Topping E30, if I connect WiiM Mini instead of Chromecast audio, is the audio quality superior?yes, it has an analog line output.
However, an external dac, even a cheap one will do better (for sure)
On toslink, Wiim can stream bit-perfect up to 24/192.Thanks, I cast Tidal wifi plus to Chromecast Audio connected to Topping E30, if I connect WiiM Mini instead of Chromecast audio, is the audio quality superior?
if I remember correctly, I had some rare dropouts during the trial period of Amazon music unlimited, while with Tidal, Qobuz or Deezer I don't remember any.I don't think it's WiiM specifically because other things inside WiiM app stream fine like Qobuz and Deezer.
The pursuit of bit perfect Amazon Music HD has been a long and pretty fruitless task up until now, and I feel it’s finally within grasp.Another day without dropouts.
I'm even now on 2.4GHz without problems - the problem with my ASUS RT-AC86U was DNS over TLS (DoT).
None of my other devices at home ever had an issue.
It's specific to Alexa Casting from Amazon Music app.
Alexa wants to see everything un-encrypted
Finally after 1 week of wanting to return it to Amazon for a refund, I can say my WiiM Mini is ready for the 24/192 casting goodness
yes, i was essentially using amazon cast from the native appAmazon Music inside WiiM HOme app perfectly fine for me the past week.
Just Alexa casting from Amazon Music app was problem, until I disabled DoT.
So I have to assume it is Alexa related.
even with an iphone 6s connected via usb, the dac always showed 192 with the amazon music hd app, when all the other services show the real frequency of the songbut it wasn’t bit perfect with my Linn MDSM/4 showing 24/192 no matter what resolution was being played.
It is because of adaptive rate streaming in Amazon's mobile and desktop appseven with an iphone 6s connected via usb, the dac always showed 192 with the amazon music hd app, when all the other services show the real frequency of the song
I always had the feeling that with that iphone, qobuz was better than amazon but not being able to compare on the fly, I always thought it was suggestion, as it probably was...It is because of adaptive rate streaming in Amazon's mobile and desktop apps
Changing sample rates during song could cause lots of issues with DACs etc.
Fixing output rate eliminates any chance of issue
What Bluesound and now WiiM have done is by-pass this adaptive rate and they just stream the FLAC file direct
The best way to test Amazon HD vs Qobuz from iOS is to only compare a PCM192kHzI always had the feeling that with that iphone, qobuz was better than amazon but not being able to compare on the fly, I always thought it was suggestion, as it probably was...
Can anyone using Amazon Music casting to WiiM Mini (not Amazon via WiiM Home) - both lossy and beta lossless - try something for me.
It might help a lot of people.
Can you change your router DNS settings to CloudFlare but using DNS over TLS (DoT). See screenshot below
I've been able to turn this on and off and the dropouts are quite repeatable at my end.
So I think I will tell WiiM Support as it might solve a lot of support tickets but would like someone currently not having issues Amazon casting, to test.
Specifically casting from Amazon Music app - not using WiiM Home app for Amazon Music
You have to select DNS over TLS (DoT) like shown below.
When I simply turn off DoT (I select DNS Privacy Protocol = None) then I have no issues using Cloudflare
So it seems DoT DNS encryption causes my disconnections.
It will be easy for you to turn this on/off
Just do a reboot of the router after you make a change. Maybe reboot WiiM Mini also.
This results in disconnections in Alexa app (WiiM Mini shows as "offline") and you can't cast to it from Amazon Music app, as it doesn't appear:
This has no disconnections in Alexa app and works perfectly (no DoT):
Thanks for confirming.I'm using 2.4GHz mesh with RT-AC86U (main) and RT-AC68U (node, which is used by WiiM sitting next to it).
Using DoT, never had issues or disconnects.
DoT settings below:
Np!Thanks for confirming.
Are you casting from Amazon Music app to WiiM Mini? (not using Amazon Music inside Wiim Home app)
Yes I did that. Starting with 44.1/16 up to 192/24. This was the cause of the doubts, together with the impossibility of changing sources instantly...The best way to test Amazon HD vs Qobuz from iOS is to only compare a PCM192kHz
