Check Qobuz settings for the streaming quality on the device: WiiM Home app->Browse->Qobuz->Top left corner (hamburger icon)->Streaming.Just signed up for Qobuz, transferred playlists from Amazon, problem is that no tracks play over CD quality on the Wiim.
Has anyone had this issue?
Indeed all for just 99. It often goes on sale. I’m not sure what those 6000 dollars streamer would provide you aside more features and better dac but even that it won’t sound day and night knowing wiim is bit perfect on its optical out. Just big profit margin.All i care about is Alexacast. Wiim slays any other streamer for Amazon HD
Hi Thomas, please go to WiiM Home App and select browse tab > Qobuz > Menu icon (left to new Releases) > Streaming. You can adjust the streaming quality there. You can also find the tutorial here. Thanks!Just signed up for Qobuz, transferred playlists from Amazon, problem is that no tracks play over CD quality on the Wiim.
Found it, thanks.... Qobuz is working great now.Hi Thomas, please go to WiiM Home App and select browse tab > Qobuz > Menu icon (left to new Releases) > Streaming. You can adjust the streaming quality there. You can also find the tutorial here. Thanks!
You should specify what set-up was for those measures.old small chromecast__ wiim
more than struggling to switch from ultra hd 192k to amazon echos etc?You will never give up on this, no matter how many times it's shown to be a non-issue. Pathetic.
The tests you are showing demonstrate - that for this topic at least - the devices are audibly identical.more than struggling to switch from ultra hd 192k to amazon echos etc?
especially since many lip service recognize not even hear obvious differences between a not bit perfect and a bit perfect ..
so between a 48k24bits and 192k 24bits...
just like the simple eq mode in flat which degrades .... not bit perfect , normal
I just politely invite wiim to take some precautions on this point... that's all...
there shouldn't be any difference...and there is...
we continue to use the dac "classify them" according to a sinad on a simple 1k while what we listen to is so so so much more complex ... while recognizing not hearing the differences in the lab above 110 of sinad. ..
amazing
ca feeds a market certainly ... but as much to smile right?
the marketing of 192k to listen to jazz rock, non-acoustic music etc. also right?
while obvious impacts on the ecological side...
"I don't hear but at least... am at the top numbers in support"
me too I recognize over the months to find it honestly a little pathetic
:-o
ps
reading you shouldn't have any differences in dac outputs according to the nature of the inputs and we can clearly see from the tests here that this is not necessarily the case?
to read you can not even exist..
the Chinese dacs so appreciated here even integrate functions to manage jitter the dac in inputs, right?
don't forget also that a test such as a multitone in ap32 you has simplified observation is of a simplicity compared even to a simple agreement of a piano...
etc then a 1k!
sorry for my bad written expression then automatically translated..
just that all this is hardly serious you will agree..
and that we all try to stop our reasoning where it suits us.. it's human
i tried switching from EQ off to EQ flat, back & forth many and many times, in near field and in the listening spot. I don't perceive anything different, even the smallest "click" of something switching. Shurely it's my fault...just like the simple eq mode in flat which degrades .... not bit perfect , normal
AFAIK WiiM doesn't read Atmos metadata nor decode DD+ or TrueHD tracks. It could probably send DD+ sound unaltered over toslink but not TrueHD due to insufficient bandwidth.I have atmost av receiver. My question how do I listen just by turning on the decoder or the music has to be atmost? Can wiim do atmost?
It simply depends whom you ask, range is between very good and very bad.(..) but in general, how is the sound from the Wiim dac?
Typically takes less than one or two seconds to start playing when I select a radio stream, and yes, even low bitrate stations sound good feeding my Linn MDSM/4 amp over spdif optical.Apologies because I'm certain the answer is contained in this thread, I will go back and look through it but if anyone can answer, in general, how is the Wiim software gui for tuning into internet stations, do they take a long time to load, do they sound clear?
I'm looking for a low power system that I can cycle through some preset internet radio stations and allows me to turn off the Iphone while the station can play on the Wiim natively.
I am not an audiophile, the sound on the analog out of a Sangean WFR-28 to my ancient tower loudspeakers sounds perfect, I'm certain this would be no different, but in general, how is the sound from the Wiim dac?
Thanks.
Fair enough but I don't feel upset when it plays lossy with multiroom, when I walking from the kitchen to toilet and back.But only if it does Utra HD in multiroom, the website is still sales orientated with the current mini, heavily promoting multiroom and 24/192 with absolutely no mention that the two don't work in tandem.
I genuinely don't think anybody that bought the 1st version thought that'd be a limitation and woud now think the sales advertising literature is misleading, in other words it's not fit for it's "inferred" purpose.
Sometimes Amazon UHD and Qobuz (and Apple) have different sample rates for same albumsCall me crazy folks but the same equipment going between Amazon HD and Qobuz for the same songs...
To me Qobuz sounds better, it's subtle but better.
Even at the same bit rates, it just seems like Qobuz sounds deeper... More detailed.Sometimes Amazon UHD and Qobuz (and Apple) have different sample rates for same albums
And of course Tidal different again with MQA.
So it's not always comparing the same bits.
