WiiM Pro - Review & Measurements (Streamer)
ENG
Copenhagen, DK
Hello VintageFlanker, thank you for the review - great - also your personal remarks, which are grounded on
measurement !
I wish we could get the item here in EU.
Overseas
Re. WIFI vs. Ethernet - my experience is that, if you power off the device when connected to Ethernet, then unplug the cable - bad luck - output remains captive to Ethernet input, you have no way to switch to WIFI. Is it a bug ?
And a general question: was there a measured device (streamer) that DOES NOT measure well for the WIFI - SPDIF out scenario ?!
symphara
Thank you for the review, looks great as a little streamer!
onlyoneme
Poland
Really good job, nice to read it. Congratulations.
One question though - is your published chromecast measure the one after FW update? Yours here is slightly worse than the one from WiiM app but mine was exactly the same, no difference at all.
VintageFlanker
VintageFlanker
Paris
If I look at "www.amazon.de" there is no Wiim Pro for sale.
I bought mine here:
179€ shipped. But it appears to be out of stock right now...:confused:
@Audiophonics has also listed it, but availability is now planned for the end of March.
Oh, I forgot that part.:facepalm: Yes, as stated, the one you see in the review is after the last update. Here is what it looked like before the update:
44.1kHz & 96kHz.
How did you measure Chromecast, to get the same plot as WiiM Home input?
onlyoneme
Poland
I've used LMS and chromecast bridge plugin. I've just repeated my test to be sure I didn't make any mistake before, and I got exactly the same results again.
I got this
just after the WiiM's release but since the latest FW update my test results show perfect transparency.
Brantome
Hope they will restock soon. It was 180 euro + 6 euro shipping to East Europe.
The WiiM website says they’re hoping to have stock in the EU/UK by March 5th viz. “Due to the shipment delay, WiiM Pro is out of stock on our Amazon Europe (DE, FR, IT, SP) listings. It'll be back to stock around March 5th. including our UK listing. Please stay tuned! “
onlyoneme
Poland
Sure, as with literally any analyzer on Earth, it may impact measurements... Yet, what exactly is the "strong processing" you're talking about ?
I think he had meant the fact that some digital measurements are meaningless with DACs like ADI-2 because ot strong jitter rejection / reclocking to the internal clock and so on. This way you would get exactly the same jitter results for Mini and Pro, but you could see clear difference when measuring on ASRC device like miniDSP Flex.
BioMedTechGuy
South Louisiana
For TIDAL usage, chrome cast Vs the Wiim app,
I read your earlier reply, about Tidal Connect through the WiiM app sounding "snappier" but I have a concern. I have been opening the Tidal app, connecting through the Chromecast feature and opening the WiiM app, which I also have set to "MQA beta" On (to do the first unfold of MQA). Am I understanding that depending on which app is on my phone's screen is affecting how the audio signal (music) is processed or "heard"?
morillon
Brantome
My understanding is that only the use of Tidal Connect allows the first MQA unfold to take place on the WiiM device, so yes, you may hear a difference by playing it by any other means.
amadeuswus
Massachusetts
Many thanks for putting the Pro through its paces. Would some of the Pro's technical problems be fixable by firmware updates (if WiiM were inclined), or are these really hardware issues?
onlyoneme
Poland
EQ distortions issue is definitely fixable by FW update. Most if not all analog flaws are probably not.
BioMedTechGuy
South Louisiana
Yea, I too need a 'Wtf is Chromecast and how does it impact my sound - for dummies'.
Actually the Chromecast Audio device is how I first resolved the challenge of how to get my streaming services from my Android phone IN to my audio equipment. I bought a nice used unit (for $50) and I enjoyed what I had, but in the process I learned of the WiiM mini pro and I got one of those a week ago.
Let me revise my question:
If the WiiM Home app is on my screen but the Tidal app is also connected via Chromecast, am I using the Tidal Connect or Chromecast "route"?
Brantome
I’m not a Tidal user, but if you’re using Chromecast, you’re not using Tidal Connect - see this link where Connect capable devices appear separately from Chromecast capable devices in the Tidal app target device list ( your WiiM Pro may appear twice on such a list as it supports both). Also, when you use Tidal Connect, the WiiM app is just a window into what’s playing and isn’t controlling the stream, it’s just viewing.
