Apollo x16claims -129dB thd+N
Dave Tremblay
Boulder, CO
I'm hoping that Amir can just measure and post here to make sure it is unbiased and consistent, both the Apollo Twin x and the Apollo x16. I also mentioned that we have to trick out our AP units to measure those levels, and I suspect it isn't straightforward to post in exactly the same format.
Feyire
Netherlands
Did you send the units to him for review?
They have indeed been kind enough to do so. I am in the process of upgrading my PC with Thunderbolt for testing.
dfuller
That is correct. We have some tricks in there, but the PGA2500 is the basis of our programmable gain.
As I recall, the marketing says you mimic the impedance of the mic preamps you're modeling - is that done with the PGA2500 or something added on? It's a really interesting and unique feature.
Dave Tremblay
Boulder, CO
That is not a capability of the PGA2500. We have proprietary analog circuitry on the front end that does that. Our Unison preamp plugins have control over that circuitry and the PGA to match the hardware we are modeling. It is a unique feature, and as a nerdy audio engineer, one of my favorites.
AllanDavidson
Disclosure: I am the Chief Architect for Universal Audio. That said, I'm not in sales, and am not trying to sell you on Apollo; just trying to answer some of these questions. Hopefully that is OK with the forum rules.
How does the Apollo Solo and Twin perform in comparison with the X16?
The only difference are I/O and Features, or there are differences in latency, performance, quality/SNR?
Blumlein 88
I have a Twin in for testing as well.
So glad to hear this. Look forward to the review.
I think UA claims 2 db less Sinad for the Twin vs the X16 and the same for everything else. Seems likely they'll meet their spec. Would make this maybe a better choice for some than the Babyface. The Babyface advantage is USB powered with the Twin is not.
AllanDavidson
Great!
My Motu M4 purchase is in backorder since June/12th!!! I may cancel it for the Apollo.
EDIT: Just learned Guitar Center filed for bankruptcy, so I may never get my Motu :(
win
Irvine CA
Hi Dave
Is there any documentation on how to perform this modification or is there someone I can ask ?
Thanks.
what a great time to be into hifi.
Manufacturer 1: we had to hack our state of the art testing machine to test how good our product is
manufacturer 2: I also can make products that are better than state of art testing, how can I also hack it?
o_O
Dave Tremblay
Boulder, CO
Hi Dave
Thanks.
We don’t physically modify the AP. We do have several units that vary in performance, and we select the best ones/channels, but our tricks are more focused on specific procedures and combining multiple measurements to measure beyond typical AP auto ranging performance. The details of this are proprietary at the moment. Wish I could share more.
JohnYang1997
China
Alright so that's a manual process of coming up the result instead. That's what I've been doing the whole time. And thanks for your reply!
Dave Tremblay
Boulder, CO
Twin X is a very similar design, but due to cost/heat/space trade-offs, it is slightly lower spec’d. Should still measure close to performance limits of the AP. I’m interested to see Amir’s results.
The Apollo Solo is in a lower spec class, but still very good. The primary constraint there is thunderbolt bus power limits.
We list all of our measured specs in the back of the manuals for each product, so you should be able to see the details.
Drivers and latency are the similar across all Apollos. Slight differences due to antialiasing filters.
Blake Klondike
I have a 1st gen. Apollo Twin-- can you give me a sense re: how its measurements compare to those discussed here? What about the headphone amp specs? I have had trouble driving some headphones with it
Dave Tremblay
Boulder, CO
Specs depend on which output, but I believe that unit topped out at 118dB SNR and -107dB THD+N.
Headphone amp could deliver a good amount of power, but depends on headphone impedance. Which headphones did you have trouble with?
Blake Klondike
Thanks for the response. The headphones I was having trouble with were either HD800s or DT 880 Pros. I suppose I could run 1/4" out into a headphone amp to solve the problem? My basic question are whether the unit is transparent as a DAC, and what are the constraints of the headphone amp. I have been using it for demo tracking, and I like the pre-amps a lot, particularly direct electric bass. But wondering if the newer or more expensive units will provide noticeably better sound quality, particularly as a DAC for mixing or critical listening. Thanks again!
Dave Tremblay
Boulder, CO
Out of curiosity, were you seeing drive issues with those headphones while you were tracking or mixing? One thing to note is that the headphone output of our devices are digitally controlled, and the max gain of the headphone amp is designed to not clip. If you are tracking/mixing (pre-mastering), you're likely leaving some headroom and not slamming the output as shown on the meters, you can't hit full power in the headphone outputs. Test the power by running already mastered content full range out of the Apollo and then crank the headphone amp.
Blake Klondike
I appreciate the response! I was experiencing low volume when listening to FLACS of Beethoven symphonies-- I have never had any problems when tracking, or mixing. Just trying to get a handle on the unit's capabilities as a DAC for critical listening of commercial material. Was thinking it may not have been designed for 200 ohm headphones. Will do as you suggest, thanks!
