Earthquake XJ-300ST Stereo Amplifier Review
This is a review and detailed measurements of the Earthquake XJ-300ST stereo amplifier. It was kindly donated by a member for testing. It costs US $462.83 from the company website.
I like the compact packaging and old school but solid feeling switchgear. Likewise, having a low-pass filter (no doubt to drive subs for which they are famous), filter corner frequency and phase come in handy. And of course the integrated volume control. Back panel is typical with the exception of crossing terminals (for bridging):
12 volt trigger is icing on the cake.
Unit runs is a "class J" amplifier and was cool and comfortable during testing.
Amplifier Measurements
Here is our usual dashboard:
We have massive mains spike which I could hardly reduce no matter what I did. I am assuming it is internal leakage. Can't figure out why one channel is so much more distorted than the other. Averaging the two, the amp falls in "poor" category of all tested with a SINAD of 59:
Frequency response showed strong roll off at both ends of the spectrum:
There is a note about a 15 Hz high pass but nothing about the top end. I tested the programmable lowpass by more or less setting it to 80 Hz and got this:
Earthquake XJ-300ST Stereo Amplifier Low Pass frequency response Measurements.png
Crosstalk is very poor:
SNR was poor likely due to high levels of power supply/mains noise:
Power is modest:
I have no idea how they have arrived at their power spec:
Earthquake XJ-300ST Stereo Amplifier Max and Peak Power 4 ohm Measurements.png
Finally, here is the 8 ohm performance:
Not much to hang your head on here other than the compact size and functionality. Not sure how it is suitable for subwoofer duty when it has so little power. Can't recommend it.
XaVierDK
Well with this and my experience with Earthquake's FF-12 subwoofer, which they incidentally claim is a 400W sub with frequency response down to 25 Hz, which turned out to be categorically wrong, I think I'll just write off the manufacturer in general going forwards.
fordiebianco
British Isles
Blimey.
Phantomuser
Byron Shire Australia
Didn't earthquake start out years ago making knockoff copies of early Hifonics amps?
JSmith
Algol Perseus
Thanks for the review Amir.
See this kind of this annoys me... it's just a waste of the planet's resources to make such substandard products, when it could be done well for little further cost. The fact it doesn't match the quoted specifications is bordering on misleading as well.
As for "class J";
Class-J amplifier that provides the same efficiency and linearity as Class-AB or Class-B amplifiers across a broad frequency range due to absence of the resonant impedance condition, such as short-circuit or open-circuit. The Class-J PA increases the fun-damental voltage component assisted by the second-harmonic voltage by employing a capacitive harmonic load [10]– [12]. However, a complex load impedance at the fundamental frequency is required to shape the voltage waveform. As a result, the performance of the Class-J PA is degraded due to the phase mismatch, making it comparable to that of a harmonic tuned linear PA, such as a Class-AB or a Class-B, but the reported Class-J PA provides better efficiency than the theoretical expectation.
JSmith
Vladimir Filevski
As for "class J";
Earthquake's "class J" must be something different (intentionally mislabeled, maybe?), because real class J amplifiers work exclusively at radio frequencies.
AudioSceptic
Northampton, UK
Power is modest:
This would be poor at any price, but for $463 is outrageously bad. WTF are they thinking?
CedarX
USA
From the XJ-300R user manual (different model):
“What is a class J?
Class J is a monitoring circuit that optimize class D amplifiers. The class J is a class D amplifier which has a microprocessor Algorithm that trades in high efficiency for high quality throughout the audio spectrum. So in simple terms, the class J gives you the highest efficiency possible without compromising the quality.
The XJ amplifiers possess an oversized power supply: 8 ohms, 4 ohms and even 2 ohms. These amplifiers will deliver clean accurate sound with massive damping factor.”
A clever Class-D implementation or Marketing BS? (I vote for the later!)
sarumbear
If this is bordering on misleading, what is a plain lie in your opinion?
Vladimir Filevski
“What is a class J?
Class J is a monitoring circuit that optimize class D amplifiers. The class J is a class D amplifier which has a microprocessor Algorithm that trades in high efficiency for high quality throughout the audio spectrum. So in simple terms, the class J gives you the highest efficiency possible without compromising the quality....
Yup, that is.
tomtoo
Germany
Or is this thing build for bassshakers and shows more power at low impedance?
FeddyLost
IMO if you don't have decent engineer, then you can hire good manager who can find out good OEM platform (like something inside QSC GX3) and stick your label to it.
Both options are failed here as I see.
This class J means junk.
sarumbear
The product page has no mention of power capability at all. (I wonder if that happened after @amirm's test?)
The user manual has the following specification where it clearly, in bold, says it is not suitable for low impedance loads.
2 x 110 Watts RMS @ 8-Ohm
2 x 170 Watts RMS @ 4-Ohm
1 x x 170 Watts RMS @ 8-Ohm Mono
1 x 300 Watts RMS @ 4-Ohm Mono
(Do not use this amplifier in 2-Ohm)
The difference between what is promised to the buyer and what is delivered is almost two-fold. A big fat lie. That is what it is.
It is pretty funny that they have no engineering knowledge at all. They say do not use this amplifier in 2-Ohm but specify both per channel and the bridged operation at 4-Ohm...
JDS
Power is modest:
In addition to the power issue, a subwoofer amp that's down 3dB at 30Hz is rather ill-conceived.
