Earthquake XJ-300ST Stereo Amplifier Review
bidn
Kingdom of the Netherlands
This class J means junk.
Absolutely right!
I assume this is why there is no poll (at least right now) at the top of the review : voting is not possible yet because the most relevant category for that device is still missing: Piece of junk.
sam_adams
This review finally proves that not all amplifiers sound the same.
vkvedam
Coventry, UK
Either way it did create an earthquake one way or another with this kind of performance ;)
Doodski
I think this is a outlier. I googled class J extensively and found limited details on it but what I found was not stated to be for audio use.
MinMan
Unfortunately Earthquake may no longer be using ATI as their OEM....
sarumbear
Specifications​
  • Power Output:
    • 2 X 110 WRMS (8-Ohm Stereo)
    • 2 x 170 WRMS (4-Ohm Stereo)
    • 170 WRMS @ 110 volt AC (8-Ohm Mono Bridged)
    • 210 WRMS @ 230 volt AC (8-Ohm Mono Bridged)
    • 320 W-IHF (dynamic power) @ 230 volt AC (4-Ohm Mono Bridged)
  • Frequency Response: 20Hz–20kHz
  • High Pass Filter: 15Hz
  • Phase Infinitely Variable: 0–180°
  • Crossover: 50Hz–160Hz
  • Signal To Noise: 101dB
  • Load Impedance: 2 Ohms or greater
  • THD: 0.08%
  • Damping Factor:> 1400
  • Power Line Voltage: 110-220 ~ AC50/60Hz
Why? Have they been?
digicidal
Sin City, NV
I think the fact that this isn't the worst measured amp so far speaks volumes (pun intended) about the competition. :confused:
Xyrium
Ouch, agree on the waste of our planet's resources, and is also a good point. Damned shame...
ROOSKIE
Minneapolis
Another case for the pretty scrappily but reasonably decent for $100-130 Monoprice 605030, it smokes this amp.
Ron Texas
One almost has to go out of their way to get such a poor SINAD when there ae so many amps on a chip that perform much better. Thank tou @amirm
dualazmak
The company shall never be successful in Japan, active tectonism/diastrophism place...
newaudioguy77
Looking at the frequency response roll off....
It kind of makes sense for them to call this thing the Earthquake XJ-300ST!!
High magnitude. Lots of damage. Audiophiles evacuated the premises.
XaVierDK
I almost want to see a review of their $1000 DSP-controlled 700W amp now.
But I'm not sure anyone should waste their money for our entertainment.
