Geshelli JNOG2 Review (Balanced DAC)
Rate this DAC:
    Votes: 12 5.4%
    Votes: 70 31.4%
    Votes: 107 48.0%
    Votes: 34 15.2%
Jimster480
Tampa Bay
I like the the form of this unit but as I only need to clear 16-bit audio, and I don't need USB, there must be means of making a cost-reduced version, perhaps with a cheaper DAC chip. Perhaps I should get into this business.
You can buy it for less without USB...
The DAC chip used isn't very expensive anyway... You would save like $10-15 maybe. Not worth it.
If you want a cheaper DAC overall then there are cheaper ones...
T&T
Objectively you can look that up. Subjectively I am not sure if anyone has both to say.
I just get the new geshelli akm4499 with stock opa1656...sweep the floor of the smsl su1 with power supply upgraded, if this was a boxing fight the smsl is knocked out in the first 10 seconds.
I just ordered 1 sparkos ss2590 custom dual mounted with raisers, from what I read on YouTube several members said is better than ss3602 and beating some r2r,
No pop noise skipping music using Spotify / Wiim Pro/ Chromecast.
Extremely happy with my first 20 minutes of listening.
Veri
First 20 minutes?? A bit early to be making boxing fight analogies...
