Isn't the SMSL SH-9 better performance than this with lower price?
It means they designed the whole amplification circuit with transistors (one could also use tubes) and capacitors and resistors etc. rather than using an operational amplifier or chip, which is a device made by a chip company that amplifies the signal. A chip or op amp is more complex and simplifies the engineering and design. There is no sonic or measurement advantage to a discrete circuit. It is just that they pulled off a difficult challenge in getting this level of performance in a discrete circuit.Can someone explain to me what do you mean by discrete circuit? Any advantages/disadvantages?
You gotta learn how to be patient kid,good things come to those who wait.I am going to try to sum it up: we don't want H16. We want X16 deliveries, and we don't care MQA. Deactivate it by software modification and deliver the X16 already paid please.
The ESS chip is MQA capable. Not sure you can just de-activate it. In any case, it feels like ESS is partly to blame.. was there any procedure for the licensing? Really just "you can buy our chips, rest is up to you" ??. That's some Wild, Wild West shit, honestly.I am going to try to sum it up: we don't want H16. We want X16 deliveries, and we don't care MQA. Deactivate it by software modification and deliver the X16 already paid please.
A discrete circuit is constructed of components which are manufactured separately. Later, these components are connected together by using conducted wires on a circuit board or a printed circuit board. The transistor is one of the primary components used in discrete circuits, and combinations of these transistors can be used to create logic gates. These logic gates can be used to obtain the desired output from an input. Discrete circuits can be designed to operate at higher voltages.Can someone explain to me what do you mean by discrete circuit? Any advantages/disadvantages?
One can deactivate it in the dac registers. It's eventually up to the end manufacturer to decide to use it and to go through the certification or not. It's basically an equivalent to a program or a section of a code built inside the chip. Just like whether you want to use the MQA library for XMOS. It's the same. It's there and if the designer wants to use it the product will need to go through the MQA certification process.The ESS chip is MQA capable. Not sure you can just de-activate it. In any case, it feels like ESS is partly to blame.. was there any procedure for the licensing? Really just "you can buy our chips, rest is up to you" ??. That's some Wild, Wild West shit, honestly.
This is just only audio, a cheap DAC. Not a really big affair anyway.The ESS chip is MQA capable. Not sure you can just de-activate it. In any case, it feels like ESS is partly to blame.. was there any procedure for the licensing? Really just "you can buy our chips, rest is up to you" ??. That's some Wild, Wild West shit, honestly.
It would be unusual to have a seperate volume control for pre out, line level pre out, or a selection. Most people prefer to have the gain and control there. Good luck.The Gustard manual for this unit is somewhat sparse in regard to information.
I already have an X16 on order and am wondering if I go XLR from the X16 to the H16 whether the pre-out can be configured for fixed level output on the XLR output?
I am hoping to use the H16 to pass the audio on to an integrated with XLR input but don't want to worry about the current volume level.
The Topping A90 manual definitely indicates that the pre-out is subject to the current volume setting.
Two things to notice.
1, The amplification circuit is discrete. So this proves that discrete circuit can also have great performance.
2, The max output power for 300ohm is hindered by its gain setting. There's no excuse in relay based design. Would be great to see 50ohm bal output power tho. @amirm
Overall Atom level of THD+N, SP200 level of noise, Violectric level of power(supposedly). Pretty ok. Not as impressive as X16 but still good enough in most cases nonetheless.
Great review as always.
I like and will pay for a good attenuator. I don't require it, but if good attenuators continue to become more common, I will.I like the volume control. Not having to deal with scratchy pots is so high on my list of purchasing amps these days. Also nice to see no channel issues practically speaking.
Excuse my lack of very basic knowledge...
At times I think I know just nothing...
Are you saying that volume control matches both channels perfectly while moving, say, from 10 to 95, but left channel could become being reproduced on the right hand one and viceversa if I happen to move the volume down to zero and insist doing so ?
Thank you...
No problem. You're right.You do know that product development and product distribution are separate parts of the company, right? It is not like the R&D of the H16 delayed the manufacturing and delivery of the X16.
