Marantz AV7705 Review (AV Processor)
This is a review and detailed measurements of the Marantz AV7705 Audio/Video Processor (AVP). It was kindly purchased as a refurbished unit by a member and drop shipped to me. Normal price on Amazon is US $2,399.
I continue to not be a fan of Marantz design with the port hole requiring opening the panel below to see real information:
Back panel has the silly inputs no one uses these days such as composite and component video inputs, in gold plated no less:
Marantz 7705 Review Dolby Atmos back panel HDMI Balanced HDMI AV Processor.jpg
I powered the unit and let it go through a firmware update which took an eternity. But all was well when it restarted.
I focused my testing on the front left and right balanced outputs. For inputs I tested HDMI and Toslink.
Marantz AV7705 Measurements
As usual we start with our dashboard using HDMI although Toslink performance was identical. I adjusted the volume until I got 4 volts which is the nominal output of most stand-alone DACs:
Well, this is not good! There is a ton of distortion and it is 3rd harmonic dominated so can't hide behind "it is good distortion" line. I played with various "pure" modes and it didn't make a difference. The SINAD of 75 dB is one of the worst in any AV receiver or processor I have tested:
You might say that 4 volt output is high so let's test different outputs:
Marantz 7705 Output vs distortion Measurements Balanced HDMI AV Processor.png
Best performance is at 2.5 volt but even then, SINAD doesn't improve beyond the red ("poor") range of AV products we have tested.
I was hoping dynamic range was better but it is not:
Jitter performance was poor indicating a number of interference sources:
Could linearity be better? Of course not:
Intermodulation vs level shows the high noise floor, not being better than a freebie phone headphone dongle:
The DAC reconstruction filter is the typical very slow and wrong type:
This exerts a penalty on our THD+N vs frequency test due its wide bandwidth:
But there is more that is wrong here as changing the sample rate to 192 kHz would eliminate that factor. We see a bit of reduction at the top end but performance is still quite poor. We can see why if we look at the spectrum at 1 kHz:
The spray of distortion seems to go on forever so adds up to high THD+N with 90 kHz bandwidth (dashboard is at 22.4 kHz).
Multitone produces subpar performance as well:
Conclusion
It is simple: Marantz group takes perfectly good platform uses in its sister Denon division and screws it up across the board. Everything is degraded no matter what we test. It really is time for Marantz to go back to producing well engineered products rather than chasing subjective aspects they can't demonstrate. And poor notions like the slow reconstruction filter. It is depressing to test an AV product in 2021 with such poor performance. :(
Needless to say, I can't recommend the Marantz AV7705. Get a Denon AVR, shut off its amps and use it as a processor instead.
OK, this is embarrassing. I had reviewed this unit before! The owner said it would be 7706 and I did not pay attention to the model number as I did the review just now.
Good news is that it performs very similarly to the first sample.....
AdamG
Moderator
Reality
Multiple sample testing has value. So not time wasted and proves consistently with your testing process/procedures. Might want to include Sample 2 in title.
enricoclaudio
Houston, TX - USA
I was like… Hmmmm didn’t Amir test this thing before? Dejavú? No, I was right Lol. Thanks @amirm for the second try ;) This one proved that the AP 555 is still well calibrated :D
Dzhaughn
That's so adorable. I appreciate your courage in running this website! Good news indeed that the results are similar.
Is there any data on the variation in performance of audio equipment, as far as variation between individual units? I mean, we could test 20 SMSL DACS and look for differences. How do manufacturers test individual units? It can't be the same story between SMSL, Schitt, Denon, and Naim, can it? And what about speakers?
Lawyrup843
@amirm Great review! Is buying a Denon and disconnecting the amps really the only good option for a pre/pro these days? (Without spending more than 10K)
beeface
That we know of - I think it would be good to have a bigger sample size before declaring it though. It’s still possible that some models from other brands like Yamaha and Onkyo/Pioneer are decent, too.
nagster
Conclusion
As soon as you saw the dashboard, you must have wanted to stop the measurement.
However, you did not give up and made a series of measurements.
Bad information is also interesting to me.
Thank you very much.
DiscCollector
What does Sound United have to say when you ask them about this stuff? It's been going on for quite some time now, and with the world being more connected and more people doing their own research, their internally-created marketing hype can only take them so far before word gets around about their actual engineering (and resultant sound quality) and they're viewed as a joke.
Dmitri
I love it...I absolutely love it.
Amirm, you made disorganized and hopelessly A.D.D. me very happy this evening.
Thanks for that!
Peternz
Still junk, but what do you expect? I am sure AV enthusiasts will be thrilled with all the stuff that can be connected to it and salesmen of such stuff will be celebrating big bonuses.
Thanks for your great work as usual, your service to the community is massive. You have helped me save money and improve my audio system and I am sure many can say the same.
Aperiodic
Aimed at old timers who say 'Marantz is a good name' because their dad had one in 1967
They say that this is the "tuning" performed by the Marantz "sound engineers." Fortunately there is some sign that the latest stuff is not going in this direction anymore.
Remlab
Oceanside California
Amir, it's easy to lose track when you test such an extraordinary amount of products. This just goes to show you that. Thanks again for all you do.
