Newman
- Joined
- Jan 6, 2017
- Messages
- 3,535
- Likes
- 4,374
Try re-reading my posts after looking up the meaning of scientific control. Your listening tests are not controlled. So they are liable to be corrupted. For example, you think you did a listening test Denon vs Marantz that was all about the sonic attributes of the sound waves in the room. But to actually do that, and not be corrupted by other sonic factors, and even non-sonic factors like bias, you had to do a much more strictly controlled listening test.I have no idea what "test controls were unbalanced in the opposite direction" even means. All I know is there are balanced outputs, and it goes without saying that the levels of all channels need to be balanced.
An example: if the M was even slightly louder than the D, then you are very likely to prefer the M. That's an unbalanced test control. But if it was "unbalanced in the other direction", then you are very likely to prefer the D.
But that is only an example. There are numerous other ways that uncontrolled listening tests can mislead us.
