Can someone check from the REW file below if this is time aligned or not?
I don´t understand your question and can not answer it. But a few things i suggest from seeing the mdat-file:
- Try not using psychoacoustic but var smoothing
- Try only EQing the two peaks at 138 and 183 Hz (same for both channels)
- Try higher stands on desk instead of tilting up
- You seem to have a big dip around 70 Hz (matching the peak at 138, i guess) because of room modes, hence the loss of bass. Try a different listening position.
- If you don´t have a measurement mic yet, consider the Neumann MA 1, although you would need an additional interface and cables.
Edit: This is you measurement in a different view (R + L average) - you can try other targets, of course:
Addition:
-Try not using the "small desk" switch if you use EQ anyway.
-Try putting them even closer to the wall.
