Review and Measurements of Marantz AV8805 AV Processor
Kal Rubinson
Industry Insider
NYC
Not debating but I just can't see the cause-effect you're proposing.
I have heard from a couple of smaller "high-end" companies that encumbering support for HDMI has caused them to exit the A/V or processor business or to not enter it.
Sal1950
The Chicago Crusher
Central Fl
My review of Emotiva indicates, look elsewhere for midrange AV processors.
There was a time when Emotiva seemed to work hard at offering good value for the money stuff. That has appeared headed down hill over the last few years. :(
RUR
SoCal
Made me look.
So, I read about two "high-end" AV Processors...….
Neither says it does anything to the video except switch it.
As a rule, folks @ the high end who use Datasat/Theta/Trinnov/Storm etc products are building 16-32 channel home theaters, often costing well into six figures, don't care about video handling in the processor. They'd rather use Lumagen or similar products to handle switching, LUT support etc. etc.
Kal Rubinson
Industry Insider
NYC
...............................................Neither says it does anything to the video except switch it.
OTOH, all of them extract audio from the HDMI for most of their sources. (Brief statement rushed out to beat Don to the punch.)
DonH56
Monument, CO
Made me look.
I suppose they have all sorts of sound modes, certainly enough licenses attached.
Most if not all AVRs only switch the video, but the audio has to be pulled from the HDMI and that requires handshaking and interfacing that is a major headache and requires those chips Amir referenced. The spec is rather poorly written (in my limited experience) and leaves too much ambiguity so getting two HDMI components to play well together can be a crap shoot. Then there are all the different cables; some work, some don't , and you have to get the right cable for the bandwidth needed... I have a bunch and most have little to no label to tell me what bandwidth it supports. I end up buying new just to avoid the hassle of spending an hour or two in the rat's nest behind the console trying to see what if any work with my new toys.
Edit: Kal beat me to it.
capitanharlock
There is other gear out there, a midrange of NAD, Anthem, Emotiva, etc. And a high end like Acurus, StormAudio, Trinnov.
We just lack anyone to do honest reviews. ;)
I am torn between Nad M17V2, Anthem MV60, Arcam Mv860 and this Marantz.
Two channels audio is a must.
Really don't know what to choose.
Kal Rubinson
Industry Insider
NYC
You could, but it isn't clear whether that would be worth it since the performance of the unit as an analog preamp was not measured. I think it is unlikely that the "limitations" in the unit tested were all at the DAC level. If they were largely at the preamp level, that would make an external DAC redundant.
Drudging up an old post: Recently, I have observed that the use of a high quality (multichannel) DAC feeding the undigitized analog input of the AV8805 sounds clearly superior to running the digital source files to the Marantz via HDMI.
Bjorn
Norway
That's strange considering the first indicates a double DA conversion including the DA in the Marantz, while the second option is only with DA conversion of the Marantz.
It must mean the HDMI input is suffering from jitter and the extra DA conversion from the multichannel DAC is so transparent that it really doesn't add much.
Sal1950
The Chicago Crusher
Central Fl
I gotta ask.
Could you explain the conditions and data results of your DBT please. ;)
vert
Switzerland
I have observed the same ; stereo DAC (with AK chip) , different Marantz model (with an AK chip as well)
Kal Rubinson
Industry Insider
NYC
No. The multichannel analog inputs of the Marantz are not digitized so we are comparing two different connection configurations that also differ in which of the two devices does the single D/A conversion.
Kal Rubinson
Industry Insider
NYC
I gotta ask.
Thanks for the smiley but I acknowledge that I do not and cannot perform DBT. The reason I bring this up is to suggest that measurements of the analog-only signal path would be relevant.
Sal1950
The Chicago Crusher
Central Fl
It's extremely difficult to accurately deduce the signal path going on inside these complicated devices with confidence. I only question that the two DAC's would sound so clearly different in and of themselve. If the observation is accurate, there must be something else at play here.
Blumlein 88
I don't know, but I'll ask are you sure that is how it works? A few years back was working on a Denon for someone, and there was no analog straight thru. All analog inputs were sent thru an ADC and then output from the DACs. That particular Denon has a power supply issue on the ADC which made it noisy. Adding a big capacitor and shielding fixed it. Denon and Marantz are made by the same company, but not necessarily identical of course.
Doing measures of the analog inputs/outputs would of course be a good idea.
DonH56
Monument, CO
I believe Marantz says the analog is straight through, no digitization, which also means no processing (no soundfield modes, no bass management, no room correction, etc.) Some other products I have (and had) work that way as well; a select set of analog inputs go through a purely analog path with no ADC or DAC in the path. OTOH my Denon and Pioneer Elite digitized everything all the time.
Kal Rubinson
Industry Insider
NYC
The two paths also differ in that one is via USB to the external DACs and the other is HDMI directly to the Marantz.
That used to be common in the past but, more recently, D&M have either removed the 7.1 analog inputs entirely or, if they are retained, remain analog. I have made several inquiries to D&M since the AV8801 and they have been consistent in confirming this.
Yup.
LTig
Europe
In the user manual Marantz specifies a frequency response of 10 Hz – 100 kHz ( +1, –3 dB) in Direct mode. This is a hint that analog signals are not digitized in Direct mode.
Yep.
Kal Rubinson
Industry Insider
NYC
Also.........................................
Analog
S/N: 105 dB (IHF–A weighted, Direct mode)
Distortion: 0.005 % (20 Hz – 20 kHz) (Direct mode)
Digital
S/N ratio — 102 dB
Total harmonic distortion — 0.008 % (1 kHz, at 0 dB)
Sal1950
The Chicago Crusher
Central Fl
Analog
Digital
S/N ratio — 102 dB
equals = "analog input of the AV8805 sounds clearly superior to running the digital source files to the Marantz via HDMI" ???
Something isn't adding up?
