Review and Measurements of Topping D10 DAC
daftcombo
Which serial number do you have.
I'll check tonight.
EDIT: I have a good reason to think that my tweeter has inverted polarity, so if the D10 also has, it would explain why I end up with a normal polarity on the graph.
Snarfie
Netherlands
I don't know, my son removed the sticker with serial. I purchased it in May 2018.
Probably you have the same serial as i 1804 bought it at exactly the same time/month. That batch range from 1801 to 1805. The leatest serial is 1806 so was wondering if this inverted thing has to do with a specific serial code. Mabey Amir could see if his version tested has an inverted signal in one of his measurments. On the other hand i realy can't hear the difference with Foobar2000 combined with the "Simple Polarity Inverter" addon
Snarfie
Netherlands
I would be surprised if you could. :)
For me the first time i did a Polarity check. however i did it with my small IMF Monitors. Will test it again with my fullrange JK Optima 3 speakers when i got my revised Audax HIF13 speakers back. The voice coils are beeing cleand an realinged after 40 years or so. This Optima 3 speakers have a Focal woofer symetrical placed inside the speaker. Me is told (already maney years ago) that an inverted signal has the most effect on low frequensies because the woofer is moving inward instead of forward so the moment of attack is different or is this bul...t.o_O ?
Krunok
Zg, Cro
It is not, but I would still be surprised if you could hear it. Btw, I wouldn't say that "moment" of attack is different, it is the direction, moment stays the same. :)
magicscreen
Topping D70 SINAD = 110
Topping D10 SINAD = 106
But, does the D70 sound (much) better? So you would rather buy the D70 if you have the money?
Zek
Does anyone think SINAD can determine how the device sounds?:rolleyes:
Krunok
Zg, Cro
You would need to measure some other parameters as well, but basically yes, as a single parameter is is quite usefull in determining if DAC is transparent or not. To our ears D70 and D10 would both sound the same - totally transparent.
HAL9000
The analog output stage of a DAC is a critical element in the DAC's
And directly determine the sonic success of the DAC.
I've listened D10 , D30, D50 , D70....
They are all very similar.
And in a price range of $ 100- $ 900, everything is very similar. Similar chips, output opamps, measurements.
Two discrete I/V stages with no opamps in the output is next level in sound.
For example
http://www.easyaudiokit.com/bekkan/manual/RenewDiscreteIV.pdf
http://www.easyaudiokit.com/bekkan/manual/DAC9038DManual.pdf
These two PCBs are insane.:D
Krunok
Zg, Cro
Because, as everybody knows, opamps are bad for sound, right? :facepalm:
But let me guess - you can't offer a proof of that claim, aside from your hearing impressions, correct?
HAL9000
The proof is in the pie.
This is the same as if someone said the chip amp is better than discrete MOSFET amplifier in class A.
No one can prove that the opamp is better. Measurements are the same.
But the ears hear differently.
Krunok
Zg, Cro
Oh, you are one of those guys with "golden" ears? But you have never tried to listen to different DACs and amps in a proper blind test, correct?
It is your mind that "hears" differently when you know what you are listening. The moment you wouldn't know which device is playing you would quickly realise that most of the decent ones sound exactly the same. I suggest you do a little reading before posting on a scientific forum, otherwise be aware that your subjective claims will be heavilly criticised here.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
For example
Wow...With boards like that, it JUST HAS TO sound better... So...Almost like magic, it does...
HAL9000
Two dual power supplies, two dual ES9038PRO DAC, two dual discrete I/V stages. Filter bandwidth adjusment. Filter Shape adjustment (Fast Roll-Off Linear or Minimum Phase or Hybrid) . THD compensation adjustment. Digital volume, Noise Dither ON-OFF, De-emphasis selector, Jitter Elimation ON-OFF. Master Trim setting, SW check and update, Frequency Calculator, DSD Bandwith set….
The problem is a price tag who does not know how to make a DIY DAC like this (It's not cheap either in the DIY version). From $ 3500 up to $ 16,000.
BDWoody
Chief Cat Herder
Moderator
Almost as if expectation bias is a thing! :D
Everyone should have their private audio Idaho...
In mine, I raise the unicorns that vomit the USB cable coating that really opens up the soundstage in ways that are impossible to measure, but any phool can hear it...
Krunok
Zg, Cro
Wow.. I always suspected unicorns exist but didn't even dream they would turn out to be that useful with audio!
