I did notice a little drop with test tones around 12 kHz but nothing really dramatic.
Anyway I'm old and above that frequency can't really hear anything.
I like how it sounds and decodes both PCM & DSD. At least as much as I like most of more expensive DAC.
If you have fine ears and want a workaround for the FR you can use a DSP chain in foobar2000 v1/v2 with dbPoweramp:
Configure the first as follow to up-sample to 88.2 kHz everything below at the same base sample rate:
Excluded rates:
8000,16000,24000,32000,48000,64000,96000,88200,176400,192000,352800,384000,705600,768000
Configure the second as follow to up-sample to 96 kHz everything below at the same base sample rate:
Excluded rates:
11025,22050,44100,88200,96000,176400,192000,352800,384000,705600,768000
If you have something above 768 kHz add the rates at the end of the string of both.
You can do the same with the SoX mod2 plugin but it's only available on foobar v1.
Excluded rates:
Excluded rates:
